Question about Magellan Maestro 4040 GPS Receiver
My magellan 4040 will not hold a charge. I thought it was the cord and bought a universal cord for the car and it still will not hold the charge. Help
    President:
  • 1,111 Answers
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below (magellan 3000.3050 and the 6000 take about 10-15 seconds to start from the off position)
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Standing Member of G.O.T.
Posted on Nov 04, 2010
Installed a new battery in my magellan maestro 4040. battery has been charging for over 12 hours. only 2 bars like original battery.
with the 4040 plugged in to the charger, wiggle the cord to different positions and see if it loses contact (stops charging)
this model has a very common problem with the power port failing..iif it loses contact by testing it in the manner i suggested, it will require either a new one install or at the very least, resoldered,
let me know what you find and ill help you further.
bill
Apr 24, 2010 | Magellan Maestro 4040 GPS Receiver
Magellan 4040 charging issue
Click HERE for the user manual and go through it carefully you will find the solution.
Goodluck..
Feb 24, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 gps
the folowing advice pertains to the following magellan gps systems.
bill
Apr 11, 2010 | Magellan Maestro 4040 GPS Receiver
Cord will not light up or charge magellan
if the light does not com one on the car charger, try another charger if you have one, or a home charge if you have one of those...this model also has a common problem if you have a good charger.
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Feb 07, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Will not charge thru the USB or the car charger. Is the battery replaceable?
a magellan 4040 can not charge through the USB port and if it wont charge with a known good car or home charger, then read below.
Make sure
You can
Jan 18, 2010 | Magellan Maestro 4040 GPS Receiver
Magellan 4040 won't turn on or charge.
Make sure
You can
Jan 12, 2010 | Magellan Maestro 3250 GPS
I plugged it into the car charger but wont power up thought the cord was bad bought a new one but still wont power up
if this is for a 4040
bill
Dec 27, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan 4040 wont turn on
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 13, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 won't take a charge.
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it them selves
Jul 20, 2009 | Magellan Maestro 4040 GPS Receiver
I have a Magellan Maestro 4040 That will no longer pingower on.
this is a very common problem with these magellan 3140 and also the 3100,2000,2200t,2500,4000,4040 and the 4050 most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ... to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Nov 12, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
105 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
