Question about Samsung Q1 Ultra Tablet PC
The screen will not power on
When I turn the device on, a green light comes up on the top showing me that it did turn on, but nothing at all shows up on the screen.
  • 1 more comment
  • slba34g May 12, 2008
    The product is: NP-Q1Ua000/SEA and operates on Vista home premium. I tried that website already, and for some reason when I click on the link for display problems in the troubleshooting section, nothing else pops up to help me, it just has a blank area. I can click on "How To" for instance and other information will pop up. I think the other name for the model is Q1U-V.
    The hold button is not on. I can turn the hold button on, and the light will flicker at the top showing that I have done so, but when the hold is on or off nothing appears on the screen. It is just black.
    I have a Samsung Q1 Ultra (NP-Q1UA000/SEA) that runs on Vista Home Premium. When you power on the device, nothing appears on the screen. The green light will stay on showing that everything is working, but I can not see anything. The hold button is not the issue, and I have checked out Samsung's trouble shooting website with no luck. Can anyone help?
    President:
  • 2,712 Answers
Try installing THIS file..
You can also try reinstalling the graphics driver and the chipset driver.
If that does not work, you may want to try upgrading the firware to version.03ME. If your problem resulted becuase of upgrading, you will want to try downgrading to version.02MF
If none of these work, the the only solution is to contact Samsung for a resolution of this issue..
Their number is 1-800-726-7864 Mon - Sun: 9am - 9pm (EST)
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 12, 2008
    Genius:
  • 2,035 Answers
The problem is with the display or the ram is defective you need to get it serviced or use this number company number:
mobile phones : 1-888-987-HELP(4357)
Mon-Fri : 7am-9pm (CST)
Sat: 9am-6pm (CST)
Digital TVs : 1-800-SAMSUNG (726-7864)
Mon - Sun : 9am - Midnight (EST)
Printers : 1-800-SAMSUNG (726-7864)
24/7
all other products: Mon - Sun: 9am - 9pm (EST)
good luck...............
    Genius:
  • 1,447 Answers
Is the product still within the warranty period? honestly if you have tried all the steps and still you are getting blank screen, that is already a hardware issue. might as well call your product vendor. Thanks for using fixya!
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 12, 2008
    Or try downloading the graphics driver from this link, this might help...
    Q1U-V
  • Samsung Master
  • 13,433 Answers
Do you hear the windows starting up with the speakers or harddrive use?
If you don't then there is most likely a fault in the mainboard or some other part.
A bios post card would tell us where the fault is, im not sure does this laptop have a minipci slot in the bottom or not
something similiar to this
http://imgs.inkfrog.com/pix/ehkseller/RIMG0555.JPG
But it doesnt fix the problem it tells you what is wrong. or what is happening currently / where its stuck at.
I would recommend you take it to a professional pc repair shop to be analysed if your not willing to buy such card. Its most likely a problem with the motherboard as you dont hear any beeps but the lights come on.
  • Ekse May 12, 2008
    the powerlights dont tell anything about the condition of the computer the only thing they show that the power is turned on. I've receaved many laptops with similiar issues and in most cases it has been the motherboard that was faulty / broken.
  • Ekse May 12, 2008
    If your not able to start windows these driver suggestions are quite useless.
    Well hows it going can you start windows or not?
  • 58 Answers
What is the product model i know it is a Q1 but there should be more to it than that ie. Q1b Q1-p ssd Q1ucmxp and so on if this is the case, you can follow this link http://www.samsung.com/us/support/troubleshooting/troubleshootingGuidesMain.do# for the troubleshooting guide and choose the tablet pc link from there then follow the instructions
thanks good luck IAn C
emmit6378@yahoo.com f
  • 3,037 Answers
If your Q1 won't turn on and the charging light just flickers, most likely you have inadvertently shifted the Hold slider button and your Q1 is on Hold. The Hold function prevents most functions on the Q1 from operating.
To get your Q1 to turn on, shift the Hold slider button so that Hold is turned off.
this button should be on the side of the device
let me know if you need further help
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri May 12, 2008
    Here is a picture of the button, (the top long one)
  • Benjamin Patri
    your screen connection could be loose, what you can do is open it up and check this connection. you need to remove the outer panel to get to this part
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    Please don't forget to let me know your thoughts about my
    solution.
    If your problem is fixed, please rate this solution as that is one of the
    biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to
    help.
    Thank you
  • Benjamin Patri
    Benjamin Patri May 19, 2008
    Have you tried calling Samsung about this problem. If you need anything else, please let me know.
It wont turn on when charging the red light is on for abut 4hours and then turns green i unplug it and it wont turn on ive holding down the volume + and power button and still nothing
tablets are designed to be throwaway.
you can buy new batteries off ebay but replacing the battery will require cutting and soldering as the batteries in these tablets are soldered directly to the board and are stuck in place with glue and electrical insulating glass tape. Not a big job but fiddly and anyone with a soldering iron skill and basic leccie-tronics can do it.
it may be the battery - when you press the power button does the screen flicker or does the green power light come on.
pressing the power button whilst pressing the up or down volume button should take you into recovery mode - do this whilst the power block is plugged in - if the tablet shows signs of life with the power block plugged in you can be sure its the battery..
when tablets are vroken its usually by being dropped and this can cause the screen connector to come loose so you get no display but power lights will still be on.
Apr 26, 2015 | Nabi 2
My Kobo Aura HD's comfort light is off and I can't find a way to turn it back on.
On the top of the e-reader, to the left of the on/off slider (looking at the screen) there is a push button on/off switch for the light. Once the light is turned on (and there is a 'star' symbol on the screen, the brightness can be adjusted by touching the 'star' and using your finger to slide the brightness control).
Mar 19, 2015 | Kobo Aura HD E-Reader
My 7" zeki tblet model TBDG773B comes on and shows android and nothing else will.
You can try a factory restore, but if that doesn't work you will need to buy a new tablet. These cheap tablets are throw-aways unfortunately. Note that a factory restore will erase any files you have on the device.
Factory Restore on Android devices:
- Turn off the device
- Hold Volume Down and also press the Power button until a menu comes up
- Use the Volume Up and Down buttons to select Factory Reset (or Restore)
- Press Power to select
Oct 28, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
My kindle will not turn off
Did you try
Instructions
  1. Frozen Screen or Unresponsive Kindle
    • 1 Unplug the Kindle.
    • 2 Move the power button to the right and release. You should see a green LED light for two seconds.
    • 3 Move the power button to the right and hold for five seconds. The green light should blink three times and then the screen will go blank. Release the power button after it does.
    • 4 Turn the device back on by sliding the power button to the right and releasing it.
    Perform a Hard Reset
    • 5 Perform a hard reset if the previous steps are unsuccessful or if the Kindle screen is showing lines.
    • 6 Slide the power button to the right.
    • 7 Hold for 15 seconds.
    • 8 Recharge the battery if the device continues to be unresponsive.
    • 9 Restart the Kindle after charging.
Read more : http://www.ehow.com/how_7655306_reset-kindle-3g.html
Jul 29, 2014 | Amazon Kindle 3G
I have a PANIMAGE media tablet 7'' 2GB/GO, model numberR79RT2W5.. it turns on and thats it, it shows a constant blue line centered at the bottom of the screen, i can press the menu button on the top of the...
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Oct 26, 2013 | Generic PanImage Android MM Tablet eReader...
HD Nook wont light up could it the LCD or power switch?
my nook tablet shows the green light that it's fully charged but when trying to turn it on nothing happens the screen does not com on or the nook symbol does not light up . can any one help me out here
Sep 28, 2013 | Nook HD+
Pandigital wont turn on
i have it plugged in will not come on have a green light
showing its hooked to chargr but nothing else works.
Jul 18, 2013 | PANDIGITAL SuperNova
My Kindle is turned on ( i cant tell as my lighted cover light comes on) however the screen is still blank. What can i do to fix this? Thanks!!
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Oct 24, 2010 | Amazon Kindle Wireless Reading Device
Samsung Q1 Ultra Tablet PC Logo
378 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
