Question about Eureka 5892AVZ Bagless Upright Cyclonic Vacuum
How do I locate and find each of the filters?
  • 33 Answers
The foam & filter assembly is behind the clear door with the latch you pull up on, located above the dirt cup. The hepa filter is on the right side of vacuum as you are facing it from front.
Posted on Sep 05, 2010
How do i fix a bissel not sucking
Clean the filters. Check your User's Guide for filter locations. Or, Clean the Water Tank Filter located on the tank Cap. Clean the Flow Indicator Filter Located Under the Flow Indicator. Hope that Helped.
Jul 23, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Why won't my hoover u6434 900 turn on?
Hello! The vacuum has a thermal protector sensor that will automatically shut off the vacuum when it is overheated. The vacuum should turn back on once it has cooled down. This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are steps you may follow to check your vacuum for blockages.
1. Locate the primary filter behind the side grille. Wash the filter, squeeze it out and allow 24 hours to air dry outside of the vacuum. It should be washed about every other month.
2. Locate the secondary filter located in the vacuum base under the paper bag. The secondary filter can be washed in the same manner as the primary filter.
3. Replace the bag if it is full.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brush-roll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Hope this helps!
Jun 14, 2014 | Hoover U6434-900 Bagged Upright Vacuum
How to Troubleshoot hover and tunnel U6476
Hi! Below are step-by-step instructions for trouble-shooting your Hoover U6476.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
May 31, 2014 | Hoover U6476-900 WindTunnel Vacuum
Where are the 2 filters and part numbers for Dyson DC 33 vacuum?h
The first filter is located just above the canister and below where the brush and flat tool are stored. The second filter (Hepa) is located under the canister.
Dec 19, 2010 | Dyson DC33 Bagged Upright Vacuum
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-parts-schematic.pdf
Also, here's the link to the owners manual for your model as well:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-owners-manual.pdf
I hope this helps you,
Chris J.
GoVacuum
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
No suction
Your filters are clogged. Dysons have two filters. One is the washable one located directly beneathe the cannister. The other is a post filter located inside of the vacuum housing. This filter should be replaced by a Dyson technician. The Dyson company recommends you replace your filters every 6 months to a year, depending on how often you vacuum.
Sep 09, 2009 | Dyson DC14 All floors Bagless Upright...
Need Filter Queen Majestic Owners Manual
I downloaded and printed a Filter Queen Owners Manual from the Filter Queen.Com website. It was hard to locate on their website, but I printed it free.
Dec 01, 2008 | Filter Queen Majestic Canister Vacuum
I have a dyson alergy machine, I have emptied it, but I would like to clean the filter. I can't locate where the filter is or how to get to it to clean it. The manuel for this is not with the machine. ...
Greetings Irlawren3,
It all depends on the model you currently have. The filters on some are above the motor and some are on the side housing. Its pretty clear looking at the unit where the filters are located. I would suggest investigating your unit and looking for the filter.
When you do locate the filter, it is to be washed with plain water and allowed to dry for at least 12 hours before being put back into the unit.
One thing that helps determine the model is the color also. What color is it?
Thanks!
Dorothy
Go Ahead. Use Us.
Jul 30, 2008 | Vacuums
Vacuum Problem
The Bissell can have several filters in it, depending on the model. Some have a round hepa filter that is covered with a foam sleeve. This filter is located at the bottom of the dirt cup. Others have a foam filter that is located under the dirt cup in a pull out drawer. Also, they can have a cylindrical separator above the dirt cup which can be removed and washed. They are usually a blue plastic and you reach in and turn it a 1/4 turn counter-clockwise to remove. If your machine has the hepa filter, when you remove the dirt cup, the filter is at the bottom and you turn the bottom 1/4 turn and the clear housing will come off to access the filter. You should also check the small filter on the machine just below where the cup sits. This will only be there if your machine has the hepa filter on it.
Mar 21, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Eureka 5892AVZ Bagless Upright Cyclonic Vacuum Logo
37 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
