I have a hotpoint ultima wt741 , 3yrs old , washine machine does not show door is closed , the red closed light does come on and machine will not start and warning 'door' comes up on display panel , i have removed top of machine and removed and inspected lock switch and unplugged connector , all looks ok , no corrosion etc , all dry connections , i have refiitted door lock but , machine still cannot 'see the door closed position'
  • 3 Answers
I have this exact problem. it starts during a cycle or after and then although the door locks the light to say it is only briefly flickers on and it will not let the cycle start. I have fixed this several times but am not sure how. I replaced the part that engages the lock even though the lock works and checked the control board at the bottom to see if it had blown anything (earth or components ect) and it was ok for a week or so. It did it again, I checked the connectors again on the control board again and once again it started ok. Again it did it, this time I thought that there was nothing obvious with the control board, unless a dry solder joint which I could not see, so I just tipped the washer forward onto its front as I had been doing to get to the control board and again the washer started.
Now this washer is rubbish in my opinion with anything to do with blockages, as it used to get F error codes that I solved by cleaning the pump. now I concluded that tipping it forward could be dislodging a blockege so have just this minute decided to check the pump, even though its not a F code error, and found a ridged piece of grass stopping the ball in the black rubber going to the pump from doing its job. I have removed it so fingers crossed this is the problem and not some relay on the control board. Try tipping it forward and clean the pump out while its over, let us know on here if it solves your problem also to be conclusive this is the issue.
Posted on Sep 05, 2010
Hotpoint wf840 not starting
Machine may not be finding the signal from the door interlock, check the wire connections to it.
Dec 29, 2012 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima wt741 , 4yrs old , washine machine does not show that the door is closed , the red closed light does not now come on and machine will not start. l have removed top of machine and...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | Washing Machines
E05 error on hotpoint ultima wasing machine
E05 indicates that the pressure switch is stuck on full, this may be that your pump is jammed or blocked. Remove the filter and clean it out, also try to fish around in the tube that leads up to the drum. If this doe snot remedy the fault have it repaired by an engineer or someone whom has a rudamentary understanding of the mechanics of a washine machine.
Hope this helps, thanks for using fixya
Jul 06, 2010 | Hotpoint Ultima WF865 Front Load Washer
Error Code F-05
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit back and test.
Please rate my solution.
Thgankyou.
Feb 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
The red indicator light for the door lock is flashing, the washing machine will not operate because of this . the machine beeps a few times and then goes off
I assume that you have tried closing the door again, and making sure it is firmly latched in, if the problem pesists, then I'm afraid you may have to call an engineer.
Check your instructions, as I believe there is some reference to this problem
Hope this helps.
Dec 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Machine doesn't recognize door is closed
Open the door, and look closely at any little plastic latches to see if a small part hasn't busted off.
They usually have plastic prongs that tell a small switch inside the hole it goes into, that the door is shut. It's a toughie.
I'd google around for it. Use the talking marks " ". Like google something like "Ultima 1000" space "door won't close" or 'dryer' 'door won't close'.
That will bring up dozens of other people who've asked questions to OTHER sites.
Tried holding it shut? DOes it work when you stand there? You could tape it with gaffer tape.
Methinks, its a latch problem, something's busted off.
Feb 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
How do i change the door seal on hotpoint ultima wf860
hi this is a ten minute job take your lid off your machine and then take you soap drawer out there are 2 screws in the behind the soap drawer undo these unclip the top board as you look in side the machine and put the fasia in a safe place now you will have two screws on the top of machine from where you just took the facia off and 2 underneath the bottom by removing the plastic kicker plate undo these and open the door to the right you will see 2 screws that hold the interlock in remove these and then remove the band around the door seal normally metal with spring now lift the front of the machine upwards and that will be the front off now unclip the door seal from inside and check for holes if ok soak in bleach over night and rinse in the morning try some descaler to remove and limescale when you use machine again total 10 screws to undo really easy goodluck and please leave feedback
Sep 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
