Question about Mitsubishi VS-45607 45" Rear Projection Television
Light defusion filter for vs45603
Plastic filter that covers the screen. little holes in it
I can only find filter for vs45607, are they the same?
where do I ordfer it?
  • Mitsubishi Master
  • 8,617 Answers
Yes the 45603 and 45607 will interchange screen component not electronic parts but screen assemblies are the same
Posted on May 12, 2008
Lint screen won't go down all teh way.
take the metal duct out that the lint filter slides down into,stick the metal strip through the hole in the side of the duct so that when it's in the bottom part of strip is flush up against the back side wall of duct and it should have like a half inch or so sticking out of the hole,but before you stick it in clean out the duct and with a thin long screw driver open the plastic cover that the filter slides through and poke out any lint in the slots that the filter slides in.so unplug the dryer,remove the bottom panel of dryer,remove the lint filter and screws that hold the lint filter duct in place they are 1/4 inch head screws,clean out the duct and the side slots up above the duct in the plastic area then slide the metal strip into the hole so that the bottom part that you first put into the hole fits flush up against the back inside wall of duct and the top of strip will be flush to the outside wall of duct and like around 1/2 inch or so still showing.hope this helps
Jun 02, 2013 | Kenmore Elite He5T Dryer Heating Element...
2004 titan not blowing air out the vents except a drizzle amount
Most likely you have dirty can clogged cabin air filters. If you know they have been changed, then read no further. If they have not, follow these steps for replacement.
1. Open glove box (passenger side) and remove retractable cord on right side of glove box.
2. Remove 2 plastic hinge pins for glove box ( they pull straight out no tools & are a little hard to push back in take your time - Plastic don't break!!)
3. Remove glove box .Look into hole where glove box used to be. Right side you'll see cover with bolt in middle (8mm I think) remove cover.
4 Replace missing or dirty filters. There are 2 filters . They sit side by side.
5. Reverse process to close.
FYI : Home depot furnace air filter for $3.95 can be cut to size and works just great for a lot less than the $30. cost of these filters at some places. You can make 2 sets and have a replacement for next year!! Enjoy!
Aug 26, 2011 | 2004 Nissan Titan
Engine cooling fan has quit working ? at first it wouldn't shut off and now it wont stay on
this is going to sound crazy but remove the passenger side headlight you will see the bucket assembly that the light sits in it,s plastic at the bottom of light bucket trim out a little hole about three or four inch square once removed you will see the fan relay held in by two screws if you don,t cut hole for access you will have to remove front bumper cover assembly alot of work and the hole deal is better it does,nt hurt a thing once headlight is back in you will never know little hole is there this is a tremendous time saver hope this helps
Jul 30, 2010 | 2002 Jeep Grand Cherokee
My acura mdx navigation screen went black what can i do
2002 RL Acura Navigation screen is black
May 06, 2010 | 2002 Acura MDX
The clear plastic cover that covers my screen broke
There are several different sheets of plastic that cover your screen. The outside one is the screen protector, the middle one is the lenticular screen, and the inside one is the fresnel screen. All are available at Encompass.com
Apr 22, 2010 | Toshiba 61H71 61" Rear Projection...
How do you remove rear tail light assembly to replace lamp? I remover the two screws that attach the assembly to the rear pillar but it is still attached to something else.
1. Open the tailgate.
2. Look closely at the side of the brake light cover where it is closest to the tailgate. It is black plastic.
3. You will see two roundish looking outlines in the black plastic (not the two outlines in the plastic that is the same color as your van). There is just enough of a crack to slide a small screwdriver into the crack.
4. Pop the little plastic "doors" up to reveal 10mm nuts with Philips heads.
5. Remove the bolt/screw from each of the two holes. The tail light cover will be loose, but it will not come out yet.
6. Find something small to pry with. It should be plastic or you might scratch your paint.
7. On the side of the van where the tail light cover is flush (the far opposite end of where the bolts were), push a small tool (screwdriver?) under the edge of the cover and pry straight up. There is a peg that fits snugly into a hole in the van. The peg is attached to the tail light cover. With a small flashlight, you should be able to see the peg after prying it up just a little. The peg will pop out and that will allow you to change the bulb.
8. To replace the cover, start by popping the peg back into the hole, then replace the two screws. Finish by snapping the screw covers shut.
Oct 08, 2009 | 2005 Honda Odyssey
After installing the print head and ink tanks (no lights came on despite pushing the ink tanks into place) the screen is still telling me to 'install print head and set ink tank', any ideas?
I hate to ask a "stupid" Q, but did you remove the little plastic film tabs that cover the ink outlet holes?
Gotta start with the simplest questions first.
Sep 12, 2009 | Canon PIXMA MP520 InkJet Printer
I have a Mitsubishi Model VS45603. We lost power
You will have to select the TV Menu (on the remote), go to NET COMMAND, and reassign all your devices and inputs again. You may even want to go to SETUP first to be sure the screen, video, audio, color, is what you want before assigning devices to inputs.
Aug 11, 2009 | Mitsubishi Televison & Video
Fitting air filter to E46 320d
remove engine plastic covers by taking out the 5mm allen key bolts,, then remove the pollen filter and cover on the bulkhead, under the filter there are 4 , 30torx bolts , remove these and remove plastic bulkhead, then remove the 5mm allen key bolts holding the air filter cover to the engine, then remove the cover , change filter ,
Oct 06, 2008 | 2001 BMW 330
Mitsubishi VS45603
No the VS45603 is a standard TV not HD
Jun 26, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
