Question about Refrigerators
I try to light it up on propan it start fora few seconds and the check light come on in RED
  • 3 more comments
  • deneigement_ Sep 04, 2010
    I clean all the parts around the berner each time i try to light it there are fire to the berner but it only stay on for a few seconds
    it light for the time the auto pilot is on i could here it from inside but it dont stay on check light come on
    i would like to know if the realtor stop the fire and that would cost the light to come on
  • deneigement_ Sep 07, 2010
    I sending You some pictures of the unit
  • deneigement_ Sep 12, 2010
    did you received the pictures i send of my unit by you looking at it you tell me what to check thank you Rene
  • 503 Answers
Please visit the below mentioned link for the resolution......
http://bryantrv.com/docs2/docs/R704B.pdf
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 06, 2010
  • 10,865 Answers
Hi. Begin by cleaning the burner area and all of the components. Dust is the primary culprit when these will not work. J.
Posted on Sep 04, 2010
  • Refrigerators Master
  • 8,220 Answers
What are you asking? Is this an ice box? On propane? LOL
Clarify your quesI try to light it - 06ff3d4.jpgtion. I will help
Posted on Sep 05, 2010
  • 1 more comment
  • Dan Webster
    Dan Webster Sep 06, 2010
    Why you cannot give details my nizzle? What is we workin on?
  • Dan Webster
    What you gotta do is 2 option.
    Depending on the type gas system.
    If that thang is a ODS vent free product all you need to do is remove the dust in the safety feature with shop air. Blow out the dust and the pilot will stay lit.
    If your system have thermophile and is a what you call milli-volt type then you needs ta change the thermophile. When that joker gets weak it will hold the pilot but die when the valve opens. Simply put, it can't hold the magnet and operate the solenoid anymore. I wish yall could post some picture.
  • Dan Webster
Ran out of propane ..got propane filled but heater wont come on
It probably has air in the line. You need to be careful, but try to hold in the pilot button for a few seconds until you hear or smell gas. Then, turn it back off for a few minutes to let the air clear and try lighting it again.
Feb 24, 2015 | Water Heaters
Honda HRR Mower
remove the carby are clean the corrosion from the main jet and needle seat hole
check for fuel flow through the metal tap as they corrode internally blocking fuel
Sep 17, 2017 | Garden
I open the tank but when I try to start the heater it runs for a second and then goes out as if it wasn't getting any propane.
check the flame sencor
is clean and in postion pressureswitch could be blocked , try jumping out pressure switch see if it lights , check tank is full ,
Jan 09, 2011 | All-Pro Propane Garage Shop Heaters - All...
I own a 31' trailer which has an ATWOOD G6A-8E RV Water Heater, 6 Gal electronic ignition, 2 yrs ago the pressure relief valve would open up and empty the hot water tank completely, it did this several...
Most electronic ignition models only show the red light if there is a problem, (did not ignite) for one reason or another. To start with, make sure your propane is on, and you have a good flame at stove top burner, just to be sure the water heater is getting propane, and all air is bled from the line, which may cause water heater to go into check. (red light) If it does, shut switch off, and retry. Let me know what happens. As far as pressure relief opening and emptying the water heater, and your sure it's not a faulty pressure relief valve, then there's 2 things to start with checking. 1st, does the water seem extremely hot, thus a possible faulty thermostat &/or ECO . Secondly, if the incoming water pressure is too high, that will also cause it to leak bad. Try installing a pressure regulator (usually 40 psi.) at your hose connection. Let me know what you find.
May 25, 2010 | RTO Atwood Water Heater - 6 Gal LP
MY PS3 DOES NOT SEEM TO BE WORK WITH THE HIGH DEFINITON CABLE IT CAME ON FORA FEW SECONDS THEN SCREEN COMES UP WITH NO SIGNAL then. I press the power button and my tv said mode not supported???
  • try this
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Dec 31, 2009 | Sony Playstation 3 (PS3) Console
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
