Question about Sony BRAVIA KDL-46V3000 Television
Hi,my Bravia started to have color stripes on 1/2 of my viewing screen,and now, i can only see 1/2 picture,hic,,Help !
  • 10,594 Answers
T-Con board is part of lcd panel and lcd panel seems defective in your tv problem.
Call Sony/ Store if tv is still under warranty for cover or lcd panel replacement would cost you 80% of new tv price.
Posted on Sep 04, 2010
  • Sony Master
  • 3,866 Answers
These color stripes tells me the Tcon board is where the issue is at, The Tcon is basically a decoder board in the TV that is past its prime, It will need to be repaired.
Thanks Hope this does help, please be considerate and leave feedback and ratings.
  • Sony747 Oct 16, 2010
    Sony extended the warr. of this model and has scheduled a repairman to repair it in our home at no charge. Call the support line with no hassel
    http://esupport.sony.com/US/perl/news-it...
HORIZONTAL STRIPES ON PICTURE
Hi!
Turn on the camera
Pull the lens at maximum zoom
Turn off the flash!!!!!!!!!!!!!!!!!!!!!
Shoot the picture - look into the lens.
If no motion picture shutters in the lens:
1. Faulty flex cable shutter
2. Faulty valve solenoids
etc.
Requires repair of the shutter assembly in the lens
If you saw the shutter and blurry pictures as paint - matrix defective - Replace the camera matrix.
Dec 08, 2013 | FUJIFILM Finepix S2100HD Digital Camera
What causes colored stripes when playing commercial DVDs
Check your cables first to see if they are causing it. Faulty cables can cause all sorts of problems. If that doesn't solve it it could either be that the colour settings are wrong, for example NTSC instead of PAL or vice versa. Sometimes it is something to do with copy protection. In some cases counterfeit discs, or faulty discs. And in some cases a fault on the DVD player.
Oct 04, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture won't refresh on left 1/4 edge of screen
It may and likely is a defect inside the display panel itself.
Jun 16, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Sony bravia KDL-40V4100 audio and picture cycling on and off
I'd say about the blinking to a black screen would be your cable provider. As for the stripes that means that your board panels can be going bad, you can try updating the firmware of the TV to help but if that doesn't work you're getting very close to full failure on the TV.
Dec 14, 2009 | Dell E153FP 15" LCD Monitor
Turned on my TV today to find a 5" horizontal stripe across the middle of my screen. I can view the picture through the stripe but the picture brightness on the top 1/3 and bottom 1/3 of the screen is much...
This sounds like an impact injury to the screen itself. It is likely that something may have hit the screen or if the set is old, the part inside may be starting to go.
Hope this helps
Nov 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
I just bought Sony Bravia flat screen television set today. The images on the screen are 90% greenish in color. How do I set it right to the right human color ? Please help ASAP or I will return the TV set...
go into menu, look for picture or setup mode. in setup look for chroma/color & tint/tone controls. you should be able to adjust to personal preferences. one other setting, is the color temp setting. this will allow you to change to warmer back wash. hope this helps because the Bravia is a good set
Sep 14, 2009 | Sony BRAVIA KDL52XBR2 Television
Stripes across viewing screen
almost sure this is cause by flex circuit in the zoon lens that is damaged and need to be replaced. Almost always the problem of stripes in the picture is worst when you take pictures in full zoom mode because in this position of the lens the flex circuitis is fully streched. Thats all folks
Jan 19, 2009 | Nikon Coolpix 8700 Digital Camera
Sony Bravia KDL 40 HD
it's in a service test mode. have you unplugged the tv? that should reset the tv..if you still have problems after ..it will need repair.
Sep 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
2-inch picture stripe in middle of screen.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
Dec 12, 2007 | Sylvania 6419TA 19" TV
Sony BRAVIA  KDL-46V3000 Television Logo
993 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
