Question about Samsung Heating & Cooling
U have a Korean air conditioner LG whisen i cleaned the air filters and tryed to rest the system but it is still not cooling. the display is flashing CH and 05 it goes from one to the other even when the system is off
Therinnaiguy
  • 1420 Answers
SOURCE: lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Posted on Aug 30, 2007
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
SOURCE: " CH"
if ch error is displayed on your samsung ac . press and hold the up and down arrow mark(in the ac control pannel and not in remote ) simultaneously for few sec untill u get a beep sound from it ... this is a default seting to remind u to clean the air filter
Posted on Mar 18, 2009
SOURCE: samsung bio-sleep air conditioner. 1 ton capacity. the display is keep showing me 'ch'. How to remove that
press the temparature up and down key simulteneiusly for 5 seconds on the unit when it is on.It is CHOKE indicator stating that it is time to clear your a/c filter.It happens after ever335 hrs of use
Posted on Jul 06, 2009
I have LG Whisen air conditioner but i don't have remote.how can i find it
i think you have dislexia,,or you have a japanese product and you are sol,cause i cant read japanese
May 14, 2015 | LG Heating & Cooling
I have a r/c ducted LG air conditioner. The control panel is flashing displaying CH 12. The filter is clean, so shouldn't be the issue. Do you have a suggestion?
Hi Jamie hig595, I suggest that you check around both machines to see if you can see any oil stains,: ie: inside the outdoor unit, where the pipes are connected to the outdoor machine and indoor machine, or even around the outdoor case itself. Any oil stains would suggest that your system has lost gas and therefore you will need a serviceman. If thge machine will run at all are the fans working? hope this is helpful,regards Col
Feb 24, 2011 | LG Art Cool LA121CNP wall/window Air...
Need to know how to clean filters as it is not cooling very well
dismantle face cover and remove air filter and wash then pressurized water came from faucet.
Feb 05, 2011 | LG LSC091PMA Split System Air Conditioner
The aircon is on but is not cooling the room
Please follow these steps to get better cooling:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 21, 2011 | LG LS-L1210CL Mini Split Air Conditioner
No cooling LG
Thanks. Helpful?
Jan 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
LG neo plasma air conditioner does not blow cold air
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
930 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
