Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
External hard drive making alarm noise and will not load, I tried it on two computers that it has run on in the past. It is an aluratek model AHDUB250. I have around a thousand pics from my receant tour in Afghanistan and much other impertant stuff. How can I get it running again????
A drive making noise suggests that something physical has gone wrong.  If something happened so that the OS simply can't access your data and there not too much physical damage to the disk, try one of those recovery programs, but one that doesn't attempt to fix the disk, only access the data
Posted on May 12, 2008
How do I music onto my Aluratek ereader?
First hook your Aluratek to the computer with the USB cord that came with your Aluratek. Then make sure your Aluratek is on. Go to start menu on your computer. Open the computer file it should list your Aluratek along with your computer hard drive. Left click on your Aluratek drive. It should say open. Open it then click on the file that says the type of files you want to move. Books, pictures, mp3's. Now drag and drop the files to your open file. You can also do the same with the SD card rather than the internal memory both will show up as separate devices.
Jul 07, 2011 | Aluratek Libre eBook Reader PRO Black
How do i download things to the aluratek libre?
Jun 25, 2011 | Aluratek Libre eBook Reader PRO Black
I am trying to install my new Aluratek external hard drive and after putting in the CD, nothing show up on my computer screen. I am using WIndows XP. Could you please give me some ideas on what I...
Make sure the USB, is connected properly.
I've it is, try switching between USB ports, and see of that helps.
I've it does help, it might be that this particular USB port is dead.
Jun 20, 2011 | Aluratek 3.5" USB2.0 320GB External USB...
I loaded a book on my sd card then put it in my reader then it tells me that it is incompactable I can not figure out how to read it off the sd card or how todownload it from the computer to the sd card...
First make sure your SD card is formatted for your Aluratek. You do that by hooking your Aluratek up to your computer. Turn your Aluratek on with the SD card inside the Aluratek. Go to start menu. Open file named computer. There should be your computer drive your Aluratek and the SD they will be lettered left click on the one for your SD card. It should list format. Click format. Use safe to remove hardware remove your Aluratek and SD card. Now press the reset button on your Aluratek with a paper clip or needle do not use a ball point pen. Now it should be ready to load with anything you want on it. To do that you hook up your Aluratek to your computer open the drive as stated before in your SD or your Aluratek. Now drag and drop your files into the drive you have open. It should now be compatible. I know this works I had the same issue with some of my mp3's.
Jun 15, 2011 | Aluratek Libre eBook Reader PRO Black
My Aluratek fell and crashed. The hard drive inside makes the funky noise. I got a new hard drive and I want to use the same enclosure with RFID. But it is not getting mounted after swiping the RFID. ...
A fall to the floor is really serious. There is probably more damage than just the hard drive. A fall to a hard surface is like a bomb going off for a hard drive...
Mar 31, 2010 | Aluratek AHDUB250 USB 2.0 Hard Drive
External drive not showing up on my computer I am using windows 7 ultimate
do you have the drivers installed for your external drive? If not find new drivers for win 7
Jan 14, 2010 | Aluratek AHDU350500 500 GB USB 2.0 Hard...
My PC is not recognizing Aluratek AHDUB250 External hard drive
There is conflit on the drive path.
Try changing the drive path-1st {diverce manager} then {disk management}locate your drive change the drive path
Jul 21, 2009 | Aluratek AHDUB250 USB 2.0 Hard Drive
Aluratek went away and won't show up
I have the same problem with my Aluratek AHDDS100F Sata to usb 2.0 docking unit. It will only work now if I connect it via usb 1.1. I am using a Iomega usb 2.0 pci card.
Aug 16, 2008 | Aluratek AHDU350 USB 2.0 Hard Drive
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Aluratek 500 GB Hard Drive Troubleshooting
I take it from what your saying, this is a brand new hard drive.. if so it simply means that before you can use the drive.. simply click on start, the right click on my computer and go to manage. next, click on storag and then disk management local... right click on the new drive and go to format!
hope you manage okay!
Dec 16, 2007 | Aluratek AHDU350500 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
268 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
