Question about Raymarine Raystar 120 GPS Receiver
Onze L80 cr Raytheon radar- plotter verliest regelmatig het contact met de satellieten via de aangesloten Raystar 120 GPS receiver .. Onze motorjacht is gebouwd in 2000/2001. Zou het kunnen zijn dat de interne batterij (volgens het eigenaars handboek doc # 81170-1 datum september 2000 ) in slechte staat is daar het manual 10 jaar levensduur aangeeft?. Hoe kan ik de GPS receiver eenheid openen om de batterij te vervangen. Hij is gemonteerd op een vlakke ondergrond. In afwachting van uw antwoord. Bij voorbaat hartelijk dank . Met vriendelijke groet, Bert Beek. e- mail: bert.beek @ kpnmail.
5 Suggested Answers
  • 16 Answers
SOURCE: navyex
No.
This unit was GPS with WAAS only.
No Navtex capability whatsoever.
Posted on Dec 28, 2007
SOURCE: raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
Posted on Aug 17, 2008
TechnoMarine
  • 132 Answers
SOURCE: wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Posted on Jan 17, 2010
1royp
  • 187 Answers
SOURCE: Hoe maak ik een tomtom open om de batterij te vervangen
Hi go to
http://www.youtube.com/watch?v=rCVBuXUI4HE
for a very good video on how to replace your battery
If this helps please rate me
Posted on Jul 23, 2010
True commercial freezer parts
I know about
Online copyshop in Nederland
Is het juist om te zeggen dat je deed zijn vanaf nu op zoek naar online copyshop in Nederland? Op moment heeft het geweldig had je ons ontdekt in het licht van de factthat we in de online kopie service en online printservice waarmee je zal worden voldaan. Met onze online copyshop Heeft de kosten, evenals een fatsoenlijke klantenadministratie en een top kwaliteit buitengewoon kritisch. Internet Copy Shop Stuur uw goederen snel geschieden met DHL. http://internet-copyshop.nl/
Jul 15, 2014 | Computers & Internet
Toshiba status 4041
sinds de migratie van IE8 naar IE9 is er een foutmelding 4041 onstaan wanneer we vanuit de browser IE9 een document afdrukken op de Toshiba printer. Bij meerdere pagina's gaat het goed en regelmatig gaat het niet goed bij 1 pagina. De conclusie is duidelijk dat het in IE9 zit of toch een combinatie probleem?! Waar moeten we beginnen met zoeken?
May 21, 2013 | Office Equipment & Supplies
Ik heb een dell dimension 2400 windows xp uit 2004. In de setup controle loopt hij vast met gevolg een blauw beeld scherm.en doet vervolgens niets meer.
I am using google translation to explain this to you in your language.Please read below:
Als u krijgt blauw scherm, dan is het een probleem met windows xp. U moet een reparatie-installatie van Windows XP met behulp van de schijf te doen aan u met deze computer of voor een fabriek reset te gaan. Houdt u er rekening mee dat als je een fabriek reset al uw persoonlijke bestanden, zoals Word-bestanden, muziek, films, foto's zullen worden verwijderd en uw pc zal worden als wanneer je een nieuwe pc. Alles zal worden hersteld naar de fabrieksinstellingen.
Als u een reparatie-installatie zul je er rekening mee verliest uw persoonlijke bestanden.
Als u nog meer vragen laat het me weten.
Dank u.
Sep 13, 2011 | Dell Dimension 2400 PC Desktop
Geachte heer/mevrouw, Het geluid (met name zware bassen) vervormt bij de linker boxen. Kan dit liggen aan de verbinding (antenne) of aan mijn versterker?
Hallo, met behulp van een vertaler. Zet uw luidsprekers links en rechts en kijk of het probleem is met de spreker. Het is niet een probleem met uw antenne. Nadat u luidsprekers als het geluid is nog steeds vervormd op de linker luidspreker vak dan je versterker aan vervanging toe. Hoop dat dit helpt.
Jeff
Black Forest Colorado
Feb 26, 2011 | Denon AVR-3300 Receiver
Mijn nuvi 660 vind geen satelieten meer,is daar een oplossing voor desnoods met een externe antenne.
Ik heb net het zelfde probleem, volgens de verdeler weggooien en nieuw toestel kopen.
Externe antenne aangesloten en ontvangst beter dan ooit.
Nov 11, 2010 | Garmin Nuvi 660 GPS Receiver
My GPS Raymarine (installed in 2001) with Raytheon Raystar 120 antenna indicate offen a NO FIX. A technician tells me that there must be a problem with the antenna and that the best solution is to...
Before you buy a new one if that is a raytheon raystar unit there is a lithium battery inside the unit check that first thats all you may have to replace.
Sep 04, 2010 | Raymarine Raystar 120 GPS Receiver
I got a raytheon sl70 pathfinder gps that wont get a fixed signal the antenna is wired right but there dosent seen to be power comeing out of the cord that leads to the antenna. what should i do ????? i...
If you're using a raystar 125 antenna, you will have to power the red wire + and the shield wire - separately. Sl70's don't provide power over seatalk. Also make sure your green and brown wires are properly connected. If it's a 120 just power the red and sheild(black) and leave off the all except the yellow that's your data. If you still have nothing may probably have a problem in the antenna itself.
Jan 20, 2010 | Raymarine RL70CRC GPS Receiver
Ipod nano is ingesteld op audio auto radio kan deze wel dedienen maar speeld geen geluid af
iPod Nano is aangesloten op de Pioneer Car CD Player, je ziet het menu van de iPod er wel op. Maar de Pioneer Car CD Player speelt de muziek van de iPod niet af, maar de muziek van de Radio wel.
Dus wat kan ik er aan doen zodat het geluid wel wordt afgespeeld.
Met vriendelijk groet,
Cees Sins
Dec 13, 2009 | Pioneer Car Audio & Video
Raytheon rl70
May 05, 2008 | Raymarine RL70CRC GPS Receiver
GPS Logo
125 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
