Question about Magic Chef CTB1922 Top Freezer Refrigerator
What causes containers, like pitchers to get mildew after being in refrigerator for 2-3 days?
  • 4,793 Answers
The mildew is a fungus that is always present in the air around us,it is similar to pennicilin(streptococus)so it does no harm to most of us.just smells awfull and looks horendous(you want to see it under a scope.....)it thrives on bread/dairy,in fact all food we like to eat.(although different varieties exist, in the bathroom, for example)
only defence is clean everything with clorine,but as soon as you close the door it will gain a foothold AGAIN.
Posted on Sep 04, 2010
Door gasket is black looks moldy?
Good Afternoon Friend,
I see that the door gasket on your Frigidaire Affinity washer, model# ATF7000ES, is black and looks moldy. It because the mildew is not just on the gasket, but it is in the tub and in the pump and discharge hose as well. You need to reduce/eliminate the mildew in those parts. There are a couple of things you should do to reduce the causes of mildew.
1. Run the machine once a month, using liquid bleach, on the clean-tub cycle to clean out the machine. You might need to repeat this a few times to completely clean out your machine.
2. Follow the manufacturer's instructions for the about and type of laundry detergent to use with your wash. Using too much detergent causes a buildup of detergent on the tub which encourages mildew growth.
3. After your final wash of the day, leave the door and laundry detergent open, wipe dry the gasket with a cloth.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully.
-Best Regards-
WP
May 17, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Ice smells like mildew! We purchased the refrigerator/freezer new 6 months ago. It does not seem to be a problem caused by other foods in the freezer. Model number: FFTR2126LW
Mildew smell in your ice is caused by one of three things. 1. Old, dirty, clogged water filter 2. Bad water quality from your house water supply 3. Ice that has not been used and sits in the bucket for time can become stale tasting.
Sep 01, 2011 | Frigidaire FFTR2126LW Top Freezer...
Icemaker in brand new fridge makes ice that tastes like mildew
brand new?OK...first,did you flush the water filter by dispencing 2 pitchers of water through the door.wait,that it.basicly the water in your ice maker is the same water that comes out of your tap.you may find that you dont like the filtered water, there should be a bypass plug that can go in place of the filter.solution wise thats about it.
Jul 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
My washing machine has a strong mildew, musty smell when we haven't used it for a day. Cleaned the tap in lower left corner and use the HE soap. Help!!
Hello Friend, Your problem is simple to resolve. This is a common issue. It is possible that the water quality being delivered to the washer could contain higher than normal amounts of micro-organisms causing the growth of mold and mildew. Basically what is happening with your washer, when not in use the washer door remains closed trapping in moisture which is the perfect invironment for mold and mildew to grow. You should run a large empty load with bleach and from now on just leave the washer door partially open when not in use. This should resolve your problem. Happy to help, Tim.
Jun 26, 2009 | LG Washing Machines
Need a new plastic pitcher for our villaware 5787 Smoothee
Got the number from your website and called direct to VillaWare...waiting to see if it arrives safe and sound, thanks so much!
PS...There are only a few left of this now discontinued model, so I'm glad I called (and I ordered 2 more instead)
Jun 01, 2009 | VillaWare 5787 Double Smoothee Work Top...
Water Cooler - Water has mildew taste
I just put about six cups of white vinegar (not diluted) into the reservoir and let it sit for about an hour. Then I emptied that out and flushed a few pitchers of very hot water through. It seems to have worked quite well.
Jan 09, 2009 | Hamilton Beach Water Cooler with Storage...
Air in water line how to bleed out
the frig ha a plastic resivor that has air in it
you can bleed the line by continuing to use the water dispenser and diverting it into a pitcher
you can make a transfer funnel etc out of tin foil should not take more than 2 containers ( 1 /2 gal each)
Dec 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Odor that smells like gas going from the refrigerator
Mold and mildew can cause problems like this. It is even possible that a small animal may have invaded your home and gotten into the box somehow. Cleaning the inside of the box with a dilute bleach solution may help. For continuing odor absorption, place an open container, say a 1/4 cup, of baking soda (bicarbonate of soda) in the compartment. Change as often as once a week. The powder will absorb the odor.
Jan 15, 2008 | Whirlpool ET1FHTXM Top Freezer...
Container idea for water
There really is no other way. The onnl one that makes a large opening is GE. Whirlpool has some that you can turn the water spout out to fill large glass's. But tho keep it on while you do something else, there not designed for that purpose.
Aug 06, 2007 | LG LRFD21855 Stainless Steel French Door...
Magic Chef CTB1922 Top Freezer Refrigerator Logo
63 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
