Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
Jabra 3000 only flash the blue bluetooth connection does not want to connect to my d r o i d x, who does connect all static no real connection then phone tells me no longer connected
  • 8 Answers
SOURCE: connecting JABRA BLUETOOTH to MY SIDEKICK 3
Use your Bluetooth wireless headset or car speaker to make and receive calls: 1. Follow the manufacture's instructions for your Bluetooth device to make sure it is turned on and "visible". 2. From your Sidekick, go to the Phone application. 3. Make sure your Bluetooth device has paired with your Sidekick device by pressing MENU and selecting Settings > Pairing. (If you try to do this and you don't have Bluetooth services turned on, you will be prompted to turn it on.) 4. On the Pairing dialog that appears, make sure your Bluetooth device is listed and has a key icon next to it. The key means that it's paired with your device. If it doesn't have a key, roll the TRACKBALL to select the device name, then press to pair. Once paired, press DONE . 5. Back at the Phone screen, press MENU and select Transfer Sound to > Bluetooth Device Name. 6. Dial your number and send the call. All sounds will be routed through your Bluetooth device.
Posted on Aug 25, 2007
SOURCE: connecting to phone
You need to put Jabra in Discovery Mode. Press the "Volume up" and the "Power" button at the same time continuosly while you have your Razr in the add Bluetooth mode. Once they meet you will be asked to pair, concur. Then you wilkl be asked for a passkey.. The universal code is "0000" (4 zero's).
This should get you in and working.
Posted on Dec 29, 2007
SOURCE: Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Posted on Feb 05, 2008
SOURCE: Jabra connection
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Posted on Feb 13, 2008
SOURCE: Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Posted on Dec 13, 2008
Jabra How To Connect to my PC
Hello
Are you prompted to enter a Bluetooth pairing code? The pairing code for the Jabra Solemate is 0000.
Try disabling the Bluetooth on the Windows 8.1 device and then re-enable it and then try the pairing again.
Oct 26, 2013 | Computers & Internet
I have got a Jabra BT620s and connected it with usb to Windows 7 64 bit pc. The drivers automaticly were installed and ready to use. But there is no sound trough the headset, only trough the speakers. When...
Does your computer have built in bluetooth? if yes,make sure you press and hold the stereo bluetooth till its steady blue,,not blinking blue. then on your pc, go the bluetooth section in control panel and search for devices. then you should see the Jabra Audio device.click on it to connect to the Jabra and use the passcode 0000. After it connects, the steady blue should now be blinking blue. Then go to control panel, sound and you should see the Jabra there.Right click on it and click on set as default device. Now play any song and see if you still have it playing in your speakers.Let me know if it works.I have the same Jabra and its really works great.Especially when im working out and dont want no wires around me
May 06, 2011 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
Apr 13, 2011 | Jabra Bluetooth Headset - BT2070
I purchased a Jabra bluetooth that fits on the sun visor how do I connect with my black berry
Go to options menu on BB bb_icon.gif and locate Bluetooth.
- Enable Bluetooth.
- Then turn on Jabra 250 and Hold down the Multi-Function Button until you have a SOLID BLUE LIGHT on the LED on the headset. This could take up to 10 seconds and will take place after the LED has ceased to flash.
- Click add device on your BB.
- BB will search for your earpiece. 0000 is your passkey to add device
Jan 15, 2011 | Jabra Cruiser InCar Speakerphone Black
I turn on my jabra, it flashed on and then there is a solid blue light. How do I fix this?
The solid blue light simply means your headset is in pairing mode and ready to be connect to your phone.
Sep 14, 2010 | Jabra BT350 Bluetooth Headset Headset
Cannot figure out how to pair my jabra with my blackberry bold......both work....just wont connect
Go into your Blackberry's Bluetooth menu and after turning Bluetooth on, scroll down to Bluetooth Options and select the item. A new menu will appear, scroll to the item which allows you to set Bluetooth to be discoverable (by default, it's hidden). You may have to click on Options to find this menu. You can set it to be permanently discoverable (a security risk) or to be discoverable for just 2 minutes.
Turn on your Jabra headset by holding down the main button until the blue light stays on constantly.
Go back to your Blackberry Bluetooth menu and click "search devices". After your Jabra shows in the results list, select it to add it to your phone.
If prompted for a passcode enter either 0000 or 1111 (varies by Jabra model and by the country it's sold in).
Your Jabra should now be paired and the constant blue light will revert to an intemittently flashing blue.
If this has resolved your problem then please let me know by taking a moment to rate my answer. If not, then please add a comment and I shall attempt to assist you further when I'm next online.
Jul 22, 2010 | Jabra Bluetooth Headset with Adjustable...
Can't connect
In your Jabra bluetooth headset, press and hold the button in the headset until you see BLUE flashing light. Once the light is flashing in the Jabra, go to your Motorola phone and search for any Bluetooth device in range. when the Jabra shows up, select the Jabra and put in the pin code for the headset "its either 0000 or 1234)
Cheers!
Jun 10, 2009 | Jabra Bluetooth Headset with Adjustable...
I have a Jabra set, but my Motorola Krazer can not find it
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for around 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Jabra device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 16, 2009 | Jabra BT350 Bluetooth Headset Headset
Connection prob
Brand New Jabra -BT350 won't work on my Nokia 6102i, I did everything in term of setting my phone properly to paired with the Bluetooth, My Phone Bluetooth light is on, and the device blue light is flashing as well, but it still doesn't work. the phone would ring, I hit the JABRA button to answer it.....still can't answer my phone... Please send your help to me at jjkernaud@hotmail.com
thank you all.
Nov 08, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
452 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
