Question about Dualit CTS4E 4-Slice Toaster
I need the bottom crumb catcher for my Dualit Toaster. Can you order for me? Product Code 49200 Model D4BEHUS Series 2008/04
3 Suggested Answers
  • 32 Answers
SOURCE: Dualit 20247 2-slice crumb tray needed
At the Dualit Service Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
espressonist
  • 1711 Answers
SOURCE: Crumbs stuck on the sides and bottom of toaster
You can follow the instructions on how to replace the heating elemnts of the dualit toaster in the link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
With this way you remove yours clean the toaster completely and put the elemnt back.
Good luck
Posted on Jul 26, 2010
How to clean the inside of a toaster
Slide the bottom door under the toaster and it will open, I would suggest doing it over a waste can or sink. You can take a small thin brush and get the crumbs out. Then your toaster will be back in working order. Crumbs that are stuck in the bottom of the tray is what causes it to burn the toast.
Nov 21, 2013 | Dualit CTS4E 4-Slice Toaster
Just purchased toaster oven model CE23551 and it did not have a crumb tray as advertised on the box and owner manual. Why is there no crumb tray ?
This model does NOT come with a crumb tray. In order to remove the crumbs from the bottom it must be shaken (like a toaster). I understand that this may be a little inconvenient; however, this machine is made relatively light weight for that purpose.
Mar 30, 2013 | Toaster Ovens
Our Dualit toaster doesn't work. The red light doesn't work. I have changed the fuse in the socket with a working one. The timer turns normally. Yet none of the heating units heats...
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
Jun 12, 2011 | Dualit Vario 3 Slices Toaster
Replaceing the small pull out tabs on the crumb tray
You can find these parts on E-Bay
http://cgi.ebay.com/PARTS-00322-DUALIT-TOASTER-CRUMB-TRAY-HANDLES-2-PK-/130287387597?pt=UK_Home_Garden_Kitchen_Toasters&hash=item1e55bbc3cd#ht_3490wt_883
Apr 02, 2011 | Dualit 20084 2Slice Toaster
Good luck
Jul 24, 2010 | Dualit CTS4E 4-Slice Toaster
The timer gets stuck and the toaster will stay on.
Open the bottom and shake out the crumbs. Kidding. Toasters are generally a disposable item. Depending on your affections for this crisping critter, you may find a part and you may not. I'm going to open a five dolar fis store for small appliances. So many are trashed because of penny parts. Let me have the make and model and Serial # and let me research this for you. Might as well open the doors here. This is a grand opening freebe.
Jul 01, 2009 | Dualit Vario 4 Slices Toaster
Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Sep 18, 2008 | Dualit Vario 3 Slices Toaster
Dualit 20247 2-slice toaster
Very often it's simply crumbs in the wrong place.
Unplug it and take it outside. Remove any little drawers you have completely, and brush them out with a stiff brush.
Turn toaster upsidedown, and bang the sides with your flat palm to empty crumbs. Because of the design, this doesn't get everything out, and you may need to do it upright, and upsidedown again.
While upsidedown, press the levers fully down, and agitate them on the bottom stop.
This should remove the crumbs from the electromagnet armature.
This is operates when a flat plate rests on the elecromagnet. If there are crumbs in the way - it wont hold.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Jun 25, 2008 | Dualit 20247 2-Slice Toaster
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 18, 2008 | Dualit 20247 2-Slice Toaster
Dualit CTS4E 4-Slice Toaster Logo
93 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Angel Joseph Jr.
Angel Joseph Jr.
Ross Keen
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
