Question about Nikon Cameras
Nikon f100 Rubber Grip Has Developed Sticky Spots... What can I use to clean this up...
    Brigadier General:
  • 11,967 Answers
How about using a leather cleaner?
Posted on Sep 04, 2010
Rubber getting sticky
That is a sign of age. Best thing to do is replace it.
Oct 28, 2012 | Nikon N50 35mm SLR Camera
Sticky
Possible that the rubber has vulcanized due to exposure to heat, try and use a external coat or rubber cover or you will need to replace the handle.
Mar 14, 2012 | Cars & Trucks
I have a nikon 70-200mm f/2.8 VR lens. I've had it for three years. It's tack sharp and fast to focus. It's everything as advertised. I shoot mostly sports and it's my primary go to...
This sounds like the zoom ring has had a knock somehow and it is no longer free to rotate.
I think it is too early to be wearing out.
Either way I suggest you have it inspected by a camera repair shop as it will only become worse over time.
Jun 12, 2011 | Nikon 70200mm f28G AFS VR ZoomNikkor EDIF...
Nikon F100 suddenly went dead
Which battery holder are you using? The small one or the grip MB-15? If it is the MB-15 make sure it is screwed in tight. If it is the small one then make sure your batteries are in the correct direction. If that does not work call Nikon Film 1-800-645-6687.
May 16, 2010 | Nikon F100 35mm SLR Camera
Nikon N80 takes one shot, then needs abt 10 sec cooldown
If your batteries are fresh ( have seen flat new ones older stock) and are using alkalines then I would think you have a connector problem. Can you check and clean the connectiosn inside the grip and on the camera body. I've also seen dirty lens contacts and even a sticky shutter cause this. It's usually not serious just rather annoyng until you find it.
Apr 22, 2010 | Nikon N80 35mm SLR Camera
Broken latch on camera back
An authorized Nikon dealer should be able to order the back for you. If there's no dealer in your area, Nikon's service center info is on their web site. There's currently one new back on eBay for US $98..95 from a Canadian seller with good feedback. My only other suggestion is the old joke about pros. How can you tell if a photographer is a real pro? His camera has gaff instead of duct tape.
Apr 12, 2009 | Nikon F100 35mm SLR Camera
Rubber Grip Has Developed "Sticky Spots"
The best and cheapest way I have found is to use 91% isopropyl (rubbing) alcohol...put a little on a paper towel, cloth, or cotton swab and rub the stick stuff off. I would also suggest putting on rubber gloves to keep the black stuff off your hands. Have fun.
Oct 03, 2008 | Nikon F65 35mm SLR Camera
Nikon F100 dead
I do know that on earlier models like the N90s and 8008s, the small nut that holds the battery clip in place activated a cut off switch. If the switch was faulty, the camera would not turn on. There may be a similar switch in the F100.
Aug 22, 2008 | Nikon F100 35mm SLR Camera
F100 rubber grip peeling
double stick tape is what I would use. mosts glues are to thick and not compatible with the body materials
Jan 29, 2008 | Nikon F100 35mm SLR Camera
Aperture priority not working...HELP!!
Hey Mike, This is an easy one. With the battery grip attached, you can only have either Shutter Priority or Aperture Priority work properly. You can change it with the custom function settings of the camera. So you can change it to work with Aperture Priority if you use that more so then shutter priority won't work. Brandon
Oct 21, 2006 | Nikon F100 35mm SLR Camera
Cameras Logo
695 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
