Question about Whirlpool Washing Machines
My washer fills up with water and then stops. We have been able to make it work for the last year by hitting the top of the lid. Now even that does not work?
  • 347 Answers
Replace the lid switch
Posted on Sep 04, 2010
Washer is full of water and completely dead...
the maytag atalntis is a great machine but often falls victim to the lid switch problem
try pushing in the lid switch, right in the middle on top of the lid
you will se a lil plunger, push it in
AP4008646
goto appliancepartspro.com
runs aound 20.00 but im sure thats your issue
Oct 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis Top loading washer
it sounds like a bad lid switch.
Apr 07, 2009 | Maytag Washing Machines
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Roper washer ras6233kq
Hello, So unit should fill with water though right? Just no spin and drain. more than likly you have a bad lid switch. look and see if there is a hole somewhere on the frame. usually on the lid you will see a actuator that plunges into the lid switch. When you close the lid you should hear a click if there is no click you a bad lid switch.
Dec 24, 2008 | Roper RAS6233KQ Top Load Washer
Maytag Atlantis top-load washer won't fill with water, no power.
Not the lid switch>>>The water level switch ...unless you have forgot to turn the water on,Please Rate This !!!!
Dec 01, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Fills with water and that's it
ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
Oct 21, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore washer just stopped
This is a typical symptom of a defective or loose lid switch. If you open and close the washer lid, you should hear a clicking noise as the lid switch activates. The lid switch is usually located on the right-hand side under the washer casing rim. It is activated through a small slot, by a plastic piece on the lid called a lid strike. There are two mounting screws adjacent to the slot that hold the lid switch in place. Sometimes the screws come loose, or the lid strike breaks off, causing the switch not to activate. Or..the switch simply fails over periodic use. This results in the symptoms you describe. The washer fills, but fails to spin or drain. This is a simple repair that you can accomplish yourself. For step-by-step instructions, please refer to the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require assistance in locating replacment parts and/or have further questions, please post back with your complete model number (located aorund the tub rim), along with your comments. That way I can assure the accuracy of any part numbers.
NOTE: Use care not to slam the washer lid. This can also cause premature failure of the lid switch components.
Jun 16, 2008 | Washing Machines
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
21 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
