Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
My tv turns on but doesn't show a picture - Hitachi 51F500 51" Rear Projection HDTV-Ready Television
How to fix my tv
turn up the brightness
Jul 04, 2013 | Televison & Video
My tv turns but it doesn't show a picture but you can still hear
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 28, 2012 | Mitsubishi WD-60737 60 in. HDTV
Vizio vt420m comes on then flickers and then doesn't show any picture, but the tv stays on
If you have not been using the TV for quite sometime, moisture would have developed some defects inside the TV when you switched on. Sometimes even insects and lizards might get in and cause short circuits. Anyhow this might require attention by a qualified service technician.
Jul 13, 2012 | Vizio VT Televison & Video
VC IArt tv doesn't show picture and the power button flashes
There is shorted component/s in the power regulator section to your TV. Check and replace them.
May 07, 2012 | JVC AV-27D302 27" TV
Our picture will only show reds and greens, no other colors.
Go to your On Screen Menu to picture settings and reset and choose "reset picture" mode. This will bring you back to factory defaults. If this doesn't work shut off wait 10 sec. and turn on the TV. If still no luck call your best friend who is a TV repairman, you probably have a damaged blue drive.
Oct 02, 2011 | LG 32LG30 32 in. LCD HDTV
The wii turns on but does not show a picture
Make sure your video input cable is plugged in all the way to the TV and the Wii, If that doesn't work then the cable may be broken and you may need to get another one.
May 30, 2011 | Video Game Consoles & Games
Problem to turn on Philips TV
sound very much like the C.R.T is low emission the tv monitors the tube before showing a picture.either get the tube boosted or changed most tv shops should do i
Oct 18, 2007 | Philips 27PT563S 27" TV
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
