Question about SanDisk Sansa View 8GB MP3 Player - Black
Sansa View doesn't appear in my WMP.
My new Sansa view appears in my computer. But, I would also what it to appear in the Windows Media Player so that I could sync files easily like I did to my Sansa Clip. Are there anyother ways for this device to appear in WMA in mind?
  • 758 Answers
Sorry for the delay...In order to solve your problem, I will need to obtain some additional information from you...
What version of windows do you have?
what version of windows media player?
Posted on Jun 17, 2008
I used WMP to trasfer my music to mynew Sansa View. WMP and my computer both show the music is on the player howerver when I go to the plyer it has no music on it. I have tried updating the driver, the...
Hi there, I use WMP too and have had good results with it. My thought is some files can not be played like some avi files won't work. They have to be windows compatible or they won't work on your mp3 player. Be careful what you download too (viruses) can affect your players software. I would do a virus scan before transfer. Good luck.
Jun 10, 2011 | SanDisk Sansa View 8GB MP3 Player - Black
How do u download new music and delete old music, im having trouble with this PLEEEEASE HELP
When your player is connected to your computer with the USB connector, you can use your computer file browser software to view all files on your player. Your player will appear as Sansa m230 or m240. Follow these steps:
1. Use the USB connector cable provided with your player to connect the USB port on the top of your player to an open USB port on your computer. The player will appear as a Windows Portable Device on your computer.
2. Delete your music files to the player with software tools like Rhapsody, Windows Media Player or Napster Client.
To transfer music from your computer to your player:
1. Use the USB connector cable provided with your player to connect the USB port on your player to an open USB port on your computer. The player will appear as a Windows Portable Device on your computer. (Can't find the USB port on your player? See The Basic Controls section on page 3.)
2. Drag and drop music files to the player from any location on your hard-drive
Jan 09, 2011 | SanDisk Sansa m240 MP3 Player
How do you delete photos from the mp3 player?
Link to the Sansa View manual:
http://mp3support.sandisk.com/sansa/UserManual/VIEW/View_UM_English.pdf
Deleting photos using Windows explorer, see page 26 (=24) "Deleting content"of the manual.
When using media software like Windows Media Player 11, see next link.
How to use WMP 11:
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Nov 29, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Computer doesn't recognize MP3 player -
Try to reboot your PC. Leave mp3 player off when start Sync (if button lights up this time).
Jan 20, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Cant download anything hpdv6000 to my sandisk sansa view
Install Media converter, then connect sansa. Then, it should appear in My Computer as Sansa View. You can add it there or use the converter software.
Aug 10, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa view 8 gb
I think I have a solution. If you're using Windows Media Player like you're supposed to, click the sync button in the top menu bar. if it says click here to sync device slick there and it'll pop up a menu telling you to name your Sansa and click ok and you should be good to go.
Jul 19, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
How do I get my Sansa e260 to appear in Windows Media Player (v. 11; Vista)?
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 12, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa View 8GB = would not connect
I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
Dec 26, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Can not view my music files on my laptop (but can on my desktop)
Get the latest firmware upgrade - this player wasn't originally designed with WMP 11 in mind. Also, make sure the laptop has the folders "My Documents" and "My Music" on it - this is primarily where WMP reads from.
Dec 06, 2007 | SanDisk Sansa c240 MP3 Player
I accidentaly sinc music to my sansa e250 from windows media player and it wont come off!!!
Mp3 files can be loaded using either WMP or Windows file manager (Explorer) but a different USB setting is required by each. WMP uses the MTP setting while Explorer uses MSC. If you used the wrong setting this may have caused your problem. Also for some reason MP3 files loaded using a file manager will not appear when trying to view them using WMP. To solve the issue I used the MSC setting to view all of my MP3's using file manager. I then deleted the ones I had recently added, changed the setting back to MTP and reloaded them using WMP. Worked like a charm. Hope that helps.
Aug 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
