FixYa.com
Tags:
Microsoft Windows XP Professional for PC
Windows xp professional sp2
posted by whitetailed on May 12, 2008
i need to know how to get wpa_kill.exe My activation is running down. I had to reformat. Now it says my activation code is invalid. I am using avg, tried to find the file avg deletes it. Can anyone help me?
Frustrated
Comment by whitetailed, posted on May 12, 2008
not recognized as internal or external command
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Inappropriate (40)
oldnovii
Rank:Guru Guru
Rating: 92%, 327 votes
Hi- Whitetailed - Can you still boot to Windows? If so go to your command prompt. Start>run> type "cmd" without the quotes and hit ok.
At the c:> type this: "oobe/msoobe /a" without the quotes. There's a space between the last e and the /a.
If this solves your problem PLEASE rate this as fixed. If this did not work for whatever reason, DON'T RATE YET, just add a comment letting me know what happened and I'll help you further. Thanks.
Jeff
Rating Locked! (?) whitetailed has rated this solution as Inappropriate
Can you Help with these Operating Systems problems?
E/archive RUNDELL
como lo arreglo es un programa... Answer This...
Operating Systems
vb programming
find the Furure value of an... Answer This...
Operating Systems
My Sandisk Sansa e250r keeps...
I have tried many things to fix... Answer This...
warcraft 3 frozen throne
Hello, I just got warcraft and... Answer This...
Wireshark
http://www.wireshark.org/ Im... Answer This...
Repair Service
Find Operating System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
