Question about Kenmore 62602 Electric Dryer
Dryer makes low freq rumble and associated vibration. Gradually increase in ampitude and vibration. Any suspects?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
Fisher & Paykel smartload dryer LOUD rumbling sound
post a vid on youtube and ask the question again with a link
to the vid
cheers
Oct 30, 2016 | Fisher Dryers
Electrolux EWW16489W Washer-Dryer rumble
It is difficult to assess without a visual check. Based on your description there is circulation pump (not drain pump) which can produce strong sounds when is defective or clogged and the like. So it should be open and visually check if is correct one.
Dado
May 19, 2016 | Electrolux Washing Machines
My phone is on "vibrate." How do I get it to ring.
Try pressing and holding the volume UP button while the phone is idle (not in a call). Most phones will switch from completely silent, to vibrate, to low volume and gradually increase to full volume as long as your are pressing the volume UP button. Also, make sure your phone's "Airplane" mode is OFF.
Oct 23, 2015 | LG Cell Phones
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Oct 11, 2012 | LG DLE2514 Electric Dryer
Extreme rumbling,vibration have it apart whats the best way to tell if the drum is out of round or the rollers are shot have cleaned vent and motor. motor runs smoothly on its own
You rotate the drum rollers looking for an eliptical outer surface rubber of the rollers. Also make sure the rollers do not teeter fore and aft on the roller shaft.
Next grab the idler pulley for the belt and see if there is any play in the ldler.
Worn drum felts / gaskets or a front bearing glide can also contribute to the problem
See this link for parts:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47834&diagram_id=28471897#d28471897
Item numbers you need to check are
6, (unusual wear)
14, drum gaskets {2 ea front and rear} (torn, worn or folded)
18. Just replace the belt if your into it this deep..... especially if the dryer is +5 years old
23, (roller Shaft for wear)
24, roller for wear center and outside surfaces
30. Drum glides (Kit)
A rumble is usually associated with a bad fan blade...as in the center of the fan blade hub is cracked or broken. Check the fan for play.. also hold the motor drive pulley and see if the fan rotates on the motor shaft. It should NOT rotate without turning the drive pulley
A squeal is associated with the belt or idler pulley
A thump is a drum/felt/roller/glide problem.
Thanks for choosing FixYa,
Kelly
Jan 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a vibration that gets worse as speed increases. ive had the tires balanced
Hi:
If your tires are good, the next likely suspect are the universal joints on your drive shaft. They tend to cause rumbles and vibration that varies with speed.
Nov 18, 2009 | 1988 Jeep Cherokee
Vibrations and noisey
CHECK DRIVE BELT FOR WEAR AS THIS MAY BE THE CAUSE.
Oct 13, 2009 | Miele Novotronic T1515A Electric Dryer
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Kenmore 62602 Electric Dryer Logo
126 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
