Question about LG Art Cool LA121CNP wall/window Air Conditioner
I press the remote control power button .the air con no react at all..even i change the new battery for remote control.,it is still not working.however i use same remoter control operate another air is working. Then i open the air con cover swith to test operation ..some time air con can work .some time also can not on .no react..
  • 3 more comments
  • Anonymous Jan 08, 2009
    I also have the LG Art Cool Air conditioners and the remote does not work. I point it at the unit, but no luck.
  • Anonymous Mar 12, 2014
    Hi my Vulcan evaporative air con doesn't start up when I select on with the remote. It starts for approximately 5seconds then the air flow just drops out
  • Anonymous Mar 17, 2014
    operation light keep blink all the time
  • Anonymous Mar 22, 2014
    Can heat pump be remotely controlled online.
  • Anonymous Mar 25, 2014
    Universal pcb controller was inserted, but indoor fan motor is turning in the wrong direction.
  • 236 Answers
Replace your receiver board it may be defective.
Posted on May 16, 2008
Panasonic Econavi Air Con nanoe-g timer light is blinking - no power on air con. How do I reset? Have urned power off and taken batteries out and no good.
This is telling you there is an error which you will have to find by putting the remote control into service mode. Hold the check button on the remote for about 5 seconds and the display will change to --. Then press the timer up or down buttons to scroll through the error codes. When the indoor unit beeps quickly for about 4 seconds, you have found your error code and can narrow down your search for the fault.
May 31, 2017 | Panasonic Heating & Cooling
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
I just moved into a new home and the air cons are kelvinator r51k bgce and it won't turn on when i use the remote and the batteries are working?
pull up the front cover the grill looking piece , not the air out louvers , there maybe a little button , push that in if air con starts up , then you remote sensor may be faulty or the remote itself .
Mar 28, 2014 | Heating & Cooling
How do we reset our telstar air contioning wall unit remote model #HYK-07...we changed the batteries but now it doesn't work
Hi Diane,
Your remote control has a reset button in front just below the timer button key. Press it using a pointed material like a paper clip to make it functional reset.
Let me know if the remote control still not functioning to assist you further.
Aug 04, 2011 | Televison & Video
The tv doesn't react when pressing the power button. What can I do to fix this?
Things You'll Need:
  • Batteries
    • 1 Press the "TV" button and then press the "Power" button on the remote. If the TV turns on, your remote was just switched off of TV mode.
    • 2 Reprogram your remote to your TV. Universal remote controls can be accidentally unprogrammed by sitting on the wrong combination of buttons or having the batteries disconnect from the inner connections.
    • 3 Unplug the TV from the electrical outlet for a few minutes and plug it back in. This will reset the TV in case a power surge caused the TV to become "confused."
    • 4 Replace the batteries with new ones. Do not use old batteries from a different device in your house because if the batteries do not work, you won't be able to determine anything because those batteries may not have enough juice to power the remote. Keep in mind that different devices have different needs, so the batteries may have had enough power for something else to work but not enough for your remote.
    • 5 Check the batteries to see if they are inserted in the right direction. It's possible that someone dropped the remote, the batteries fell out and then were inserted incorrectly.
    • 6 Press the "Power" button on the TV set to determine that the TV is not dead. A dead TV will not turn on from a remote.
    • 7 Program the remote to another TV. If the second TV works from the remote, the problem is with your TV's remote signal receiver
Jan 17, 2011 | Sony Rm-yd035 Remote Control
Unable to turn on aircon with remote control and no manaul on button on the air con unit
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
May 25, 2009 | Heating & Cooling
Remote's functions dont control the air con anymore.
Have you checked the battery's in your remote?
Jan 30, 2009 | Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
LG Art Cool LA121CNP wall/window Air Conditioner Logo
4,708 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
