Question about Black & Decker 19" Electric Lawnhog Mulching Mower
Hi my coopers battery mower CCM01 is fully charged but wont work , what am i doing wrong please can you help
4 Suggested Answers
  • 8 Answers
SOURCE: cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Posted on Aug 16, 2009
kevin_max
  • 37 Answers
SOURCE: It wont turn on. Battery is fully charged. What
Look inside where the battery is inserted and see if the battery terminals are bent back or spread appart too far. It is a common problem with many cordless devices.
Beat of luck.
Posted on Jan 20, 2010
mc1bean
  • 3053 Answers
SOURCE: mower will not start new battery last year and
Try putting fresh gas, new plug a must and even spray a little starter fluid in carb intake.
Posted on May 08, 2011
Hi i have a 2001 au sedan and it wont turn over.Took battery out too charge it and still wont turn over.All lights are working so not sure now.Can anyone help please?
Just the lights coming on is not enough. Fully charge your battery again and take it to a parts store. They will hook it up and see if it is good or not. Your voltage output fully charged should be at 13.6. I am guessing you have a bad battery.
Jun 03, 2016 | Cars & Trucks
How long to charge batteries for the first time?
Battery light on is the charging system fault its not charging the battery the video are example of your problem
Apr 06, 2015 | 2014 Mini Cooper Countryman
My troy bilt riding mower wont crank
Check your battery and see if its fully charged. I had a battery that the charger said was fully charged but a cell was dead. Take it to a battery store and they will check it free of charge.
If that's not the problem check all the battery cables on both ends for being tight and clean. If that's not the problem you could have a bad starter.
Jun 22, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
I hooked up the jumper cables wrong to a Mini Cooper 2005 and it wont start. What should I do?
load test the battery. Test the alternator with a multimeter, it should read between 13.3 and 14.6 volts dc. Test the alternator at idle and rev the engine to 2000 rpm. The multimeter probes are place on the battery terminals. Look for corrosion between the battery and the battery clamps. Baking soda cleans the corrosion.
Apr 23, 2014 | 2005 Mini Cooper Convertible
Lawn tractor wont start
How do you know the battery is fully charged? Simply hooking a battery up to a charger does not ensure that the battery is being charged. The symptoms you mention are indicative of a dead battery.
Jan 29, 2014 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Ariens rideing lawn mower turns over but wont turn over fast enough please help
if your battery is fully charged, then the problem may be the starter its self.could be worn bushings in the starter.
Nov 11, 2013 | Garden
I have a craftsman with a kohler magnum 18hp. If i put a battery charger on my battery it dont charge i can turn the key and it wont roll over. If i jump my lawn mower and it running i can turn the key all...
Hi, if your battery wont charge you will need to replace it and when you do you need to check that the mower is charging by checking the battery voltage with a multimeter while the mower is running. It should be around 14 volts. Regards Phil.
Sep 06, 2012 | Craftsman Garden
Hi, I have a rotak mower. It's just gone back to bosch becoz of a problem with the battery. The battery has come back empty. I just want to know how long to charge it for it's first...
The charger that comes with the mower should shut off when the battery is fully charged and you should fully charge the battery before using.
Aug 09, 2011 | Garden
7 days ago i took my battery off to charge my camera and its fully chrged i put it back onto the camera and it just wont start up. I bought another battery and fully charged it aso and it wont turn on!...
Please make sure that the battery is clean and also the terminals within are clean. If you had been using the camera prior to the charging then the camera must work unless if the battery was spoiled by wrong charging. If you can use a multimeter to check the voltage which must be as specified on the battery label. Now make sure that the battery gets good contacts into the camera when inserted. If this wont work then it possible that there are errors within the camera and you need help from the nearest Nikon center.click the link below
http://www.nikonusa.com/Service-And-Support/Product-Support.page
Mar 28, 2011 | Nikon D3000 Digital Camera
My mini has a fully charged battery but wont turn over it wont jump start but will bump start help
If the battery is fully charged and it will not turn over but will start if you push it, they it is safe to assume the starter may be bad. But before removing the starter and having it tested make sure all the wiring at the starter is connected and not loose. Also check the connections at the battery and clean them throughly. Check the battery cables for swelling or or cuts. After you clean the battery connections and are sure all cables are good and connections are tight then remove the starter and take it to an auto parts store for testing.
May 07, 2010 | 2004 Mini Cooper
Black & Decker 19" Electric Lawnhog Mulching Mower Logo
110 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
