Question about Dishwashers
There is no water going into my dishwasher ,could this be a water pump broken
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 07, 2010
MDB3100 has hard time pumping water out, nothing blocking pump
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control board
Replace if defective (note: uncommon problem).
Sep 23, 2009 | Maytag MDB3100 Dishwasher
Dishwasher will not drain water and the pump seems very hot.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Sep 01, 2009 | Dishwashers
Water not draining
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 13, 2009 | Dishwashers
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
There is a lot of excess water in our dishwater when the cycle is complete.
HI, i would insect these areas below to address this drainage issue you are experiencing.
2. Broken belt
3. Pump
4. Drain solenoid
Jun 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
The bottom of the dishwasher has water standing in it and it won't go down
This is a clogged draining system. check the following to address this issue further.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer/control
Jun 17, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water in dishwasher will not drain.
Check the following to address this issue--
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 02, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilius Dishwasher - Water will not drain out after washing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Apr 23, 2009 | GE Nautilus 24" Built-in Dishwasher
There is standing water in the bottom of my dishwasher.
Check the following.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 19, 2009 | Whirlpool DU930PWS Built-in Dishwasher
Dish washer wont drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Feb 02, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
153 people viewed this question
Top Dishwashers Experts
Owen Barnes
