Question about Nokia Cell Phones
I am using nokia-2690.if i download any game from net ,it comes in winrar format .but my phone says that "file format not supported." please give me solution.
  • 480 Answers
If you need to download game from the net which is compatible with Nokia, it has to be a .jar file.
Cheers!!
Posted on Sep 04, 2010
Download .jar or .jad file from ur phone www.wapkid.com or www.phoneky.com or m.mobile9.com
Posted on Feb 28, 2012
My mobile is Nokia 2690 when i restore my cell phone after that my memory card is automaticly lock... so please give a solution..
Hello Vivek,
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FE Explorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
Sep 06, 2011 | Nokia 2690 Cell Phone
My nokia 2690 goes off after display white screen and first showing default time n date and then goes off
Flashing of phone is the only solution.It occurs when phone is infected by virus which is influenced from memory card or the file we got it via bluetooth.So contact mobile repairing shop or follow the procedure I've given below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 2690 Flash File and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 02, 2011 | Nokia 2690 Cell Phone
My Nokia 2690 is hung-up how can i fix it
Firstly remove the memory card and try,Secondly make backup all your user data and format by using Restore All from setting.And if the problem still persist, the only way is to flash it.So, follow the steps:::
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 2690 Flash File and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
Aug 17, 2011 | Nokia 2690 Cell Phone
My mobile is nokia 2690 and my card is locked and i want to remov pasward
Please try formatting the card in a card reader using your computer.Hope this helps.Thanks for choosing Fixya.
TinuAlbinAlex.
Jun 15, 2011 | Nokia 2690 Cell Phone
Nokia 2690 memory card password remove
Hi , Follow the following steps to unlock the memory card
  • To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
  • After finished downloading, install it to your mobile phone.
  • Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
  • Run FExplorer and open the following location C:\system.
  • From the location C:\System, you will see a file named as mmcstore. Rename this file asmmcstore.txt.
  • Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
  • When you finished the above steps, you will find the password of that file.
  • With this password u can open ur Memory card
For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Nov 20, 2010 | Nokia 2690 Cell Phone
For jar files my mb. says file format is not supported !
Do you have the .jar supporter. For ex. for enablinh .rar file you need winrar. Like that do you have it. Please check it and reply.
Sep 07, 2009 | Nokia 3110 Cellular Phone
How to download the games from my pc to nokia3110 -E.raveendhran
Hello nithyashubha,
FIRST, WHY YOU WRITE IN CAPS LOCK !!
2nd, ''FILE FORMAT NOT SUPPORTED'' cause you download games for another operating systems, Search for games on .Jar 128 x 160 pixels, 1.8 inches
your phones doesn't support the other types of Files .. just .Jar
Thanks for using FixYa.
Apr 26, 2009 | Nokia 3110 Cellular Phone
How to install skinman software in my motorola l9 slvr mobile...?
You must first unzip the file.
To download WinRAR, please click the link below:
WinRAR Download
WinZip Download
After downloading WinZip (for ZIP files) or WinRAR (for RAR files), please unzip or unRAR the file.
After that transfer the skin to your skin folder of your motorola.
Thank you
Nov 24, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Cell Phones Logo
134 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
