Question about Estate EED4300TQ Electric Dryer
Dryer will not shut off, and does not heat - Estate EED4300TQ Electric Dryer
  • Estate Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Why does my gas dryer heat keep shutting off?
The solenoid coils on the dryer are acting up. This is a common problem. They work a little then heat up and short out. Easy fix I did some videos:
How it works
Replacement
Jul 22, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer runs but no heat and it does not shut off (timer not shutting dryer off)
heatman101
Jan 23, 2011 | Kenmore 63942 Dryer
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
My dryer is not shutting off/no heat
The cycle timer motor is bad. Easily replaced and you can do it yourself. Does the dryer normally heat when drying?
Sep 14, 2009 | Zanussi TD4212W Electric Dryer
Dryer runs and heats but shuts off prematurely
It could be the timer or the sensor as well. Before replacing parts, it may just need a cleaning. If you are not familiar with the product then you should call a professional. The dryer is designed to shutoff when it is overheating, which as you stated it heats up nicely, but shuts off.
Lint, the unfortunate result of drying gets on the sensors and other parts and causes them to react prematurely. If you haven't cleaned the unit, it may just need that, if not I would then say start looking at replacing parts. For safety concerns, you should have your dryer cleaned yearly.
Another thing to check is the exaust for kinks or blockage, when this happens it causes heat back into the unit and again shuts it down.
Give those a try and it may just solve your problem.
Thanks,
Paul
My Website
Jan 28, 2009 | Kenmore 63942 Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Estate EED4300TQ Electric Dryer Logo
47 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
