Question about Janome 8080 Computerized Sewing Machine
LED display on Janome Sewing Machine reads SP
Someone gave me a Janome Sewing Machine. When I turn on the machine the LED display reads SP and none of the buttons do anything. What does SP mean and what do I do to fix this problem? Please Help! Thanks!
  • 3 more comments
  • pburns Nov 02, 2008
    I had the same problem. Found your question and answer and voila! Thank you so much.
    Pam, Australia
  • Anonymous Nov 06, 2008
    Had SP too, thanks for the solution
  • Anonymous Mar 19, 2014
    janome d3050 sewing machine
  • Anonymous Mar 24, 2014
    It just keeps going in reverse. Have tried pressing on the reverse switch and then off but no luck. Can someone please give me an idea as to what's wrong with it. Thanks
  • Anonymous Mar 26, 2014
    visual display on front of sewing machine is very light can't read it very vell
  • 8 Answers
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
Posted on May 20, 2008
  • Helene1900 Jan 28, 2011
    THANK YOU VERY MUCH! This answer about SP was very helpful! I could not find it in my instruction book! Very kind of you to post this.
  • Koen Van Dyck
    Koen Van Dyck Nov 01, 2017
    Same here ! You saved me a lot of time and frustration. Thank you :-)
    New Friend:
I was trying to sew button holes and it went half way and then a code come up as bL my book has no such code help please I have a model 3022 if this helps. thank
Posted on May 15, 2013
How do I use the thread cutter?
Most of the time, you will sew a seam and then do a few stitches after pressing the Reverse button. Leave the presser foot down and press the button with the scissor icon. (That's the top-most button in the row that curves up from the needle area.) The LED will blink. If the thread cutter LED blinks when you turn on the sewing machine, press the button again. The machine will remember if the thread cutter was in use when the power went off. For some thick threads, the auto-thread cutter will not work. Instead you'll need to lift the presser foot and bring the item up to the thread cutter on the side of the sewing machine. It's towards the back of the side of the sewing machine near the needle.
You can even program in the thread cutter in memorized sewing pattern by selecting pattern 48 and pressing the M button after all the other stitches for the pattern are added to the program.
Do remember to clean the thread cutter regularly. Lint or thread buildup will interfere with the mechanism. The cleaning steps are on page 61 of the manual.
Janome has the instruction book for the Memory Craft 6300P on the product page: http://janome.com/en/machines/sewing/6300p/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/professional-series/inst-book-6300peng-fr-sp.pdf .
I hope this helps.
Oct 22, 2015 | Janome MC-6300P Heavy-Duty Computerized...
Stuck on 5P
The led light shows 5P or SP and it is stuck there I can't - Fixya
www.fixya.com/.../t25319454-led_light_shows_5p_or_sp_stuck_change
Dec 12, 2014 - the led light shows 5P or SP and it is stuck there I can't change it and the ... Question about Janome 8080 Computerized Sewing Machine.
How to Fix a Thread Jam ' Sewing Machine - YouTube
? 2:03
www.youtube.com/watch?v=TT8qvyb39O4
Sep 7, 2013 - Uploaded by Howcast
Top Rated Products for Every Sewing Project: Singer BeginnersSewing Kit: ... I've gotten longer threads ...
Oct 21, 2015 | Sewing Machines
Sp error janome 8048
This is usually meant that the bobbin winder is in engaged. This happens on my 8080, so it should also work for the 8048. Not mentioned in the manual. Found it by someone posting on the internet.
Jul 09, 2011 | Janome 8080 Computerized Sewing Machine
Janome Harmony 8080 showing SP in the display and I can't find my manual. I know I've had this issue before and the manual had the solution but I without the manual, I can't seem to fix it
SP means the bobbin winder is engaged. Move the spooler (where you put the bobbin when you wind it) to the left and your display will go back to normal.
Feb 05, 2010 | Janome 8080 Computerized Sewing Machine
The sewing advisor screen on a Janome 8000 is getting dim.
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Jan 26, 2009 | Janome Memory Craft 9000 Computerized...
Janome 8000
I took my machine in with the same problem and they told me the display was bad. They told me that they did not make this part anymore. Try and find a parts machine.
Mar 16, 2008 | Janome 8080 Computerized Sewing Machine
Problems with the memory card
HI Have you contacted either the dealer you bought the machine from or Janome directly? There is a Janome group on the internet at Yahoogroups...maybe someone there would have the answer? I've been told that the owner of Janome monitors the group--that is WOW for an international company to pay attention to the customers! Good luck,pat
Mar 03, 2008 | Janome Memory Craft 9000 Computerized...
SP in display window, no options?
SP means that the bobbin winder has been pushed to the right in preparation for winding the bobbin. Just click the winding post to the left till it clicks, and the stitch number will be displayed.
Jan 14, 2007 | Janome 8080 Computerized Sewing Machine
Janome 8080 Computerized Sewing Machine Logo
2,361 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
