Before we moved to a new house my samsung syncmaster 710v monitor was working fine but when I reconnected monitor to the cpu, no picture appears but green power led flashes and when i disconnect the monitor from cpu a little box shows on screen indicating that the monitor is not connected to cpu. cpu was turned on HELP ME PLEASE!!!!!!!!!!!!!!!!!!!!!!!!
  • 32 Answers
First make sure all cables are tight and secured, and try pressing the Auto Button on your Syncmaster? It's for auto configuration.
If problem persist and if possible can you try using another known normal monitor/LCD? Also try your monitor using another cpu or laptop.
Posted on May 12, 2008
  • 32 Answers
Open the computer, inside the computer is a video card (where your monitor connects to on the back) push the card tighter in to the main board of the computer. Vibration from travel with a desktop computer can loosen cards and parts of a computer. I would suggest you push in all cards you see to make sure they are tightly in the computer.
If you need further help, please reply before marking solution bad, thanks
Samsung SyncMaster 710v isnt responding, keeps
Hello , this is very common problem with this model .
The problem is with main board there are two solutions:
1.Replace the main board with proper part
2.The trick you can try is to add resistor 47ohm on main board chip between two pins.
If you are not familiar with electronics do not attempt to repair it by self , go to proper service center. There is always possibility of electrolyte-shock, or high voltage shock . Hope this helps.
Fix Samsung SyncMaster 710v Not Optimum Mode Recommended Mode 1280 1024 60...
Oct 12, 2014 | Computers & Internet
Monitor don't work with my CPU
first check your system resolutions on settings of display settings. what is the resolution of screen. and check monitor supported resultion information is there on monitor manual. adjust display resolution if necessary. then connect new monitor.
First you check whether the new monitor displays your system starting screen. mean before booting into windows. some text in black color.
Jun 22, 2010 | Samsung SyncMaster 743B 17 inch LCD...
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | AOpen Black 17" CRT Monitor
Problem with Samsung 17" Syncmaster 793 MG monitor
You might be having problems with the cable connection from the monitor to the video card. Check the cable for open wire.
May 05, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung 710V - controller box
your monitor's video section is fault change video amp. ic or check cpu cable(vga cable).
Oct 20, 2007 | Samsung 710V 17" LCD Monitor
Samsung 710v no display, video
do one thing remove your monitor from cpu and turn it on only your monitor if check signal cable display is comming on your monitor means you have your cpu problume
thanks
Sep 28, 2006 | Samsung 710V 17" LCD Monitor
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
