Question about Intel D945GCCR Motherboard
I cleaned my fans and reinstalled them. pc wont power up. green blinking light on mother board and power supply. did i smoke mother board
    Guru:
  • 266 Answers
No..you just not fixed the ram sticks properly.. remove them and fix properly..your pc will start.
Posted on Sep 04, 2010
MY PC Desktop won't boot up, in the back off the tower a clicking green is blinking ,and on the motherboard is also a green light blinking ; i think it is the power supply What i did before this was...
First of all this might sound silly but when you say (turn it back on disconnect my old graphics card on safe mode) did you actually pull out the graphic card from the mother board while POWER WAS ON??? if so you definitively damaged something (the mother board or the power supply) to check you could try an other power supply if it still wont work than it's the mother board, now if I've miss understood your question it sounds like a SHORT CIRCUIT somewhere on the board check for lost screws that could have fallen and running loosely on the mother board while changing your hardware...
Hope this helps!
Feb 09, 2011 | Sony VAIO VGC-RB43 PC Desktop
Gateway 825gm wont tun on. just replaced on/off switch. greem light on power supply and mother board blinking green
Make sure the small cable from the switch to the mother board hasn't come loose. It comes loose fairly easily when reinstalling the cooling fan plenum. Its happened to me twice. Its even possible to plug it in the wrong place. Doesn't hurt to double check.
Dec 24, 2010 | Gateway 825GM PC Desktop
My a730n computer will not turn on. The green light flashes in the back. Local frys tested power supply and said it was working. Fans dont come on...nothing?
it could be a mother board problem or Power supply issue. Even if the power supply works it wont supply required voltage to some components.Its better you get a new power supply and test it.Still its not working it could be a mother board issue.There will be a chance for power button issue also.
Aug 24, 2010 | HP Pavilion A730N (PJ510AA) PC Desktop
System was up an running then, Then shut down
It sounds to me like it overheated and something burnt out, but I could be wrong. The main pieces in a desktop computer are: power supply, motherboard, cpu, ram, and video card (which is on the motherboard for lower end systems.)
Each one will need to be properly tested to find out which part(s) is(/are) failing, and the failing part(s) will need to be replaced.
Apr 19, 2010 | HP Compaq Presario SR1110NX PC Desktop
Gateway GT5014 will not boot.
Ok, this is a mother board issue. the entire mother board seems to be malfunctioning. the blinking amber/green light is confirming this. the mother board may have some fried circuitry and it will have to be replaced in this situation.
I would recommend extracting the mother board and stripping it. look for any discoloring factors that will lead to a burn out location. this will direct you to the necessary repair zone.
Please rate and have a great day:)
May 13, 2009 | Gateway GT5014 PC Desktop
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
With destop wont turn on
Robert was right make sure your computer is unplug from the power strip. now check the power supply cable to the mother board, then check the power cable to the harddrive, and then the DVD.once you put the power cable back into the computer you should get the power supply fan should come on, and the cpu fan should come on.
Next once you hit the on/off switch and green light should come on.
Jan 23, 2009 | Dell (9228C) 200-Watt Power Supply
Presario S5314 St won't power up and the fans don't work
can I have more information please, from my passed exeperience I would say that he cpu has blow.
Let me know what exactly happend prior to this.
Regards,
Philip
Dec 01, 2008 | Compaq Presario 5000 PC Desktop
Amber light on power button
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Jul 27, 2008 | Dell Dimension 8300 PC Desktop
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Intel D945GCCR Motherboard Logo
76 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
