Question about Toshiba 61H71 61" Rear Projection Television
Toshiba 61" part no. question?
Do you know the part number for the high voltage transistor? mine has the same problem.
Hello: my problem is that I have audio but not video is not seen at all. Abri the part of behind of the screen and I see that two pipe estan subdued(switched off) does not have light.
My e-mail is albertoj.martellvalentin@yahoo.com
If the agradesco can help me Thank you
Posted on Jun 09, 2008
My toshiba 65hx81 cut out lastnight. All I have now is the red flashing pwer light. Where do I begin? Do you know what the issue might be? Thankis, Kyle
Frist Kyle count the number of blinks on the set when it shuts down, this is an error code related to the problem area., The most common failure in this model is the deflection power supply board. This board provides high voltage to the picture tubes and related large signal circuits. You may want to check the horizontal output transistor for shorted condition, if it is found to be shorted replace it an the flyback transformer as these two work to gether to produce the horizontal frequency to produce the high voltage.
Oct 18, 2011 | Toshiba 65HX81 65" Rear Projection...
Toshiba 57h84 sounds like it is turning on but the only thing it is doing is the red light on the power button flashes no sound on picture nothing
CK your hori output Transistor and small blue capacitor round it feed the hori output 2k high voltage cap if they are OK then Replace both of your STK ICs they will have part number on them. For Parts Call Mats 1-800-628-1118
Dec 08, 2009 | Toshiba 57H84 57" Rear Projection...
Light doesn't come on, does not purify the air.fan runs
If the little orange neon light no longer comes on, it is a problem with the high voltage board and transformer. The board sits on top between the plates and the fan.
In my instance, the board had become corroded and shorted the terminals of the voltage regulator located on the board. Also, the ground strap around the ferrite core of the high voltage transformer had become corroded an needed replacement. Also, check the circuit paths from the nearest components to the Voltage Regulator pads. Mine blew one of the circuit traces.
All in all, I replaced the Voltage Regulator, Mouser P/N: 595-UA78L12ACLPE3, Transistor P/N: 512-2N4403BU, Timer IC P/N: 595-NE555P.
The voltage regulator feeds the latter two, as well as the high voltage transformer, I replaced those components as a precautionary measure.
The terminals do get corroded, so check those as well. There are no terminals on the high voltage board other than on top of the proprietary potted black box that feeds the target and neon light. Be careful with the terminal on that box because it breaks easy once corroded. As mine did.
Those components fixed my problem with the high voltage board and no neon light.
Hope this helps, let me know if you have any other questions.
Sep 19, 2009 | Ecoquest Flair Air Purifier
Jumping Screen 61" cinemavision
Hello dana1983165,
The problem you described is caused by poor voltage regulation in the High Voltage power supply. This can be caused by a defective fylback transformer, a defective focus block, a defective HV trippler, of the horizontal output transistor/damper diode assembly. I would first check the high voltage from the flyback to see if it was fluctuating, you can do this with a high voltage probe. The I would check the horzontal output transistor out of circuit with a transistor checker to see if it passes.
If you do not have equipment what you can do is remove the deflection/HV board and order a replacement from panasonic.
Look up Panasonic's web site and contact their technical support number and call them to find out the part number and have them order the part for you. If this fails try PTS at http://www.ptscorp.com
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba 36HF71 has sound but no picture
Same problem with mine. Relays click, sound, no picture and a flashing power LED. I finally found a schematic online. I went through the high voltage circuits and found the power transistor 2SC5570 was shorted out. There is also a pico fuse in that area but my was not open. I replaced the transistor and prayed the flyback transformer was not shorted. It wasn't, I'm watching my old 36" right now. Not a bad fix (17.00) bucks. Wonder what a service tech would have charged ;)
Jan 02, 2009 | Toshiba 36HF71 36" TV
Toshiba 61H71
2SC5570, according to the service manual.
Jul 13, 2008 | Televison & Video
Tz61v61 toshiba 61 rptv theaterview
If the relay clicks you most likely have a leaky diode or bad transistor in the stand by or start up circuit. There is a manual available for that model called. Toshiba Power Supply and Shutdown circuit Troubleshooter. Its available at the following link. It gives step by step instructions so you can figure out exactly whats wrong with your set. The site emails it too you after you place your order and they also provide free unlimited tech support so you will have a resource for help if you need it. I am one of their on line support techs. I highly reccomend that Manual to any one with a toshiba that will not power up. Here is the link.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba TZ61V61 61" Rear Projection...
Model 55X70 Toshiba Projection tv
dont know about warranties but horizontal lines means your horizontal frequency which runs about everything has drifted off sync and if too high or low it will activate shut down circuits in high voltage and power suppy, even causing HOT transistor to short. good luck and call a tech.
Sep 01, 2007 | Toshiba 55HX70 55" Rear Projection...
Toshiba 61H71 61" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
