Question about Motorola Mobility SLVR L7 Cellular Phone
My SD isnt unreadable?
Help. I have same phone as yors with i gigabyte SD but it isnt working. my phone says its unreadable.
The phone requests a format but its unreadable still.
How can I make this work?
  • 183 Answers format in any system like laptop via card reader.
2. than do again format in other moto mobile which can play your mem card just format it in other mobile fully.
3.your card will readable.
Posted on May 15, 2008
HP Photosmart R725 card is unreadable just put in new SD card HELP!
Are you sure it's an SD card? The R725 works with SD cards 2GB or smaller. It will not work with higher-capacity SDHC cards.
Jun 09, 2014 | HP Photosmart R827 Digital Camera
I have an LG GT540 and i have an almost empty memory card inserted in it but it says it is removed insert a new one! What do i do? HELP!
That happened to me before. You didn't say how many gigabytes your memory card is, but i believe your phone isnt accepting your memory card because it has too many gigabytes. Try getting a memory card with less gigabytes like a 2G card.
Aug 01, 2011 | Lands Phones
Sd card is apear unreadable when i insert to my motorola phone what should i do??
Hi, Please remove and re insert your SD card. Make sure it fit perfectly ob card slot. Then check the memory status on your phone. If still unreadable please use another good card to test on your phone to know the root cause. Still unreadable? The problem is on your phone Sometimes the interface between card and board get problem due to factory defect or misuse of card. In this case you need dissemble the phone to see the problem and get it repaired.
Dec 08, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Can i use a 4gb memory card
P.50 of the above manual has a table that goes up to 1 GB for an SD card.
But, the FAQ's say that Easy Share cameras can use up to 2 Gigabytes for the SD cards.
Since your camera is from an XP Windows System era, I wouldn't expect that a 4 gb SD card would work in your camera (since it is that old).
The FAQ seems to indicate, again, that 2 Gigabytes is the maximum for an SD card (which your C743 digital camera uses).
The instruction manual seems to indicate that 1 Gigabyte is the max in the table.
Therefore, I would try the 2 Gigabyte one and if it doesn't read or format, then I would use the 1 Gigabyte as the max. for this camera, and return the 2 Gigabyte SD card.
Aug 08, 2010 | Kodak EasyShare C743 Digital Camera
I keep getting the error msg memory card cannont be read
Your camera is only supporting: SD/MMC up to 1 Gigabyte
The card that you currently have might be high speed. All should be sorted if you change the SD card to the supported MMC SD card up to 1G. There is a lever on the SD card this one might need to be changed.
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 19, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    My camera wont switch on when i insert my 4gb sd card
    Memory card support : SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
    Pls. use the supported SD card.
    Oct 18, 2009 | Kodak EasyShare C913 Digital Camera
    Unreadable memory card!!!!motorola krzr k1
    you may have to buy a memory card reader, plug it into your computer and format the memory card before it will work in your phone, or your phone may require a different format of the same card, for instance some camera's take SD cards, and some take the HD/SD card, and they are not interchangeable, the SD will not work in the HD/SD device and vice versa..........hope this helps........
    Aug 22, 2009 | Motorola Mobility Car Charger For KRZR...
    My p990i didnt work with outgoing sms. . nothing more help
    the solution is quite simple just reach yor service provider and request for the sms settings which you will get for free as an SMS
    save the settings and you'll be able to send the SMS, same goes about MMS
    pls rate the solution
    Jun 29, 2009 | Sony Ericsson K850i Mobile Phone
    Micro sd card not working
    I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
    Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
    Motorola Mobility SLVR L7 Cellular Phone Logo
    55 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
