Question about Husqvarna 28cc Gas Line Trimmer
My Husqvarna 128LD primer bulb will not fill with gas
    President:
  • Husqvarna Master
  • 1,545 Answers
The primer bulb does not have to be full of fuel for the carburetor and trimmer to operate correctly. The actual function of the purge/primer bulb is to help pull fresh fuel into the carburetor while at the same time, push old fuel/air out of the carb and back to the fuel tank. You may have bad check valves in the primer base assembly but, the machine can even operate if the bulb is only even 1/2 full or so...Make sure the fuel is moving in only one direction during and after the bulb is pushed and released. If it's not....bad check valves. These valves are very small and fragile and easily damaged by strong solvents, high PSI compressed air...and carburetor bath type cleaners. You didn't state whether the machine will start, run, what have you. Repost if needed. Please vote on this solution.
Posted on Sep 05, 2010
Drive head rotates counter-clockwise. Can't get it back into position. Use to be able to simply turn it back around. Can't now.
Husqvarna 128 LD Weedeater Repair Questions,... - Fixya
www.fixya.com > Forum > Lawn Trimmers & Edgers > Husqvarna
Recent Husqvarna 128 LD Weedeater questions, problems & answers. Free expert DIY tips, ... Drive head rotates counter-clockwise. Can't get it back into ...
HOW TO CHANGE HEADS ON HUSQVARNA 128LD - Fixya
www.fixya.com/support/t20975899-change_heads_husqvarna_128ld
Oct 25, 2013 - Question about Husqvarna 128 LD Weedeater ... SOURCE: MyHusqvarna 128LD primer bulb .... Drive head rotates counter-clockwise.
Weed eater bogs out at full throttle - Fixya
Oct 07, 2015 | Husqvarna 128 LD Weedeater
My husqvarna 128ld won't start
Do you have compression, good spark and is fuel getting into the cylinder.?
Oct 21, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
I have a 124l e-tech trimmer and the prime bubble wont fill
Sounds like you have an air leak. Either in the primer bulb is split or punctured, hole or leaking fuel line or primer bulb base, and is sucking air instead of fuel.
Aug 20, 2012 | Husqvarna 124L 28cc Gas Line Grass Lawn...
Husqvarna 128ld won't start
May have an air leak in the fuel line, primer bubble could be split or the primer bulb base is blocked.
Jun 16, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
My husqvarna 128ld starts and idles fast but only with the choke half on. Give it gas or take the choke off and it dies.
Possibly a fuel starvation issue, incorrect fuel air mix or an air leak within the fuel system
Nov 25, 2011 | Husqvarna Garden
How do i replace the bulb on a husqvarna 123 l gas trimmer, i got it off but cannot figure out how to **** the plastic housing around the bulb.
Unscrew the 4 screws from around the primer, the primer and the primer base should just pull off, there will be a diaphram under neath.
Aug 05, 2011 | Husqvarna 28cc Gas Line Trimmer
My 128LD is just about 1 yr. old. It has sat thru the winter with gas in the tank. This is the first time I've had it out this spring. When I push the primer bulb no gas is visible. Could the oil in...
Your right, what happemd when the fuel is left in for a while is, the petrol evaporates off leaving the oil gumming up everything. You can flush through with need fuel, but make sure you remove all the parts first and dont run the engine on the neat fuel.
May 09, 2011 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 28cc Gas Line Trimmer Logo
1,870 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
