Question about Goodman CLQ36AR49 Air Conditioner
My air is not getting cool. Everithing look
My air is not getting cool. Everithing look workink? What the problem?
  • Goodman Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 04, 2010
I change my magicjack go number from usa number to Canadian number after that it is stop workink,it keep asking me to check internet line.it is working perfect
if your in the US then its probaly because you need a 1 or 0 infront of the number and the magic jacks not doing it so its saying somethings wrong
Mar 06, 2015 | magicJack GO VoIP Adapter with 12 Months...
My AC stopped blowing hot or cold air. i already replaced the blower motor and the commpressor.. what could it be now??
if the blower motor is workink the the air must be going somewhere so check the pipes and ducting to see if its all conected and the vents are opening also check the air intake on the fan to make sure its sucking air in and not blowing it out. on the off chance its blowing out swop the conections round.
Jul 30, 2011 | 2004 Mitsubishi Endeavor
My problem is tha i have a LEXUS es300 1992, I removed the two block head. Now everithing is back again but the motor get hot in fifteen minut.
check to make sure the radiator is nut air bound check to see at what temp the fan comes on and check to ,make sure the fan belt is turning the water pump// 1st watch to see for air bound look in the raider fill cap watch for it to drop // 2nd if you can see the antifreeze is moveing//3rd if the fan doesn't come on you need a new temp sensor switch
Apr 22, 2011 | 1992 Lexus Es 300
My acounty is not workink varify acount is not workink what can i do?
I had also expireinced the same problem.. just change your browser to access your account for once... after that your account will work properly on your current account too
Feb 24, 2011 | Facebook Social Network
Everithing works only the heater not work
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 20, 2009 | GE Profile Harmony DPGT750EC Electric...
It stop workink if i push start power only the
Sounds like your motherboard is burnt out.
Jul 08, 2009 | Computers & Internet
SM56 modem can not workink on windows XP
Apr 02, 2009 | Arris SM56 (SM-56-PCI) Modem
1995 Lincoln Heat and Air Stop working
You have a blendoor motor that controls the hot/cold door inside the hvac box. i have seen the motors stop workink. also the actual door will break wher the motor meets the door. either way dash will most likely have to come out..good luck...hope this helps
Nov 24, 2008 | 1995 Lincoln Town Car
No heat
1.check heatar of unit.
2.wireing of heater.
heater not workink.
thermostate also check
Feb 21, 2008 | Amana PTH153B50AJ Heat Pump Air...
Goodman CLQ36AR49 Air Conditioner Logo
230 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
