Question about Amana ARB224RCB Bottom Freezer Refrigerator
Light on but not cooliong or freezing. If you put your hand right up to the temp assure in the center of the fridge, you can feel very little air coming out and it's not really cold.
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
I have a kelvinator impression series 300 and bought it second hand. The fridge component is freezing all our food and there is icicles on the back wall of the fridge. I have tried changing the thermostat...
I have the same fridge.only a week a go my wife bumped the temp control in the freezer. It ended up freezing up so much. The fan that blows the cold air down to the fridge, couldn't . If you take everything out of the freezer. There are little plastic round caps covering the screws in the back panel. Remove the caps ta
Jan 27, 2014 | Refrigerators
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
Samsung Refrigerator RS261MDPN starts up when plugged in for about 10 seconds then stops. The center light of the freezer temp indicator blinks. compressor does not run in this mode. Also,is the...
Samsung fridge wont start compressor right away. There is delay, so when you plug fridge in it take 15 - 20 minutes to start.To check if fan is running, you need magnet. Place it on top of door hinge. Open door and if lights are out, you are in wright spot. Take magnet of to test if lights come on. Now put magnet back and if fridge fan is running you can feel it how it blow from different outlets inside of fridge .
Jul 23, 2011 | Refrigerators
The bottom crisper in my refrige freezes my veggies
To repair this problem I dont think just toggling a lever is going to work. You need to locate what is suppose to sense the temp in the fridge section and how it stops the air flow to the fridge section. Basically most refrigerators cool in the freezer using the freon coils and transfer the cold to the fridge section using the fan in the freezer. Then your thermostat (temp sensor) stops the air flow by either turning off the fan or closing a small door going to the fridge section. This door is called the baffle and if you put your hand up to it and can still feel air coming thru when the temperature is 39 degrees or lower its not doing its job. With a model number I could help better but my guess is if its not freezing everything only the veggies your thermostat is off or the baffle is unable to close all the way and may have ice or debris in it. Either way I hope this helps.
Jan 24, 2010 | Refrigerators
Freezer cold, refrigerator warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 10, 2009 | Refrigerators
I have a Kenmore model no. 596 52672202 side by side fridge that's an '03 or '04. Over the past few days it gradually got warmer on the fridge side..the freezer still freezes but isn't as cold as it could...
Hi..
In your problem you just check this following
Good luck !!!
Regards
PCmania
Jul 07, 2009 | Refrigerators
Refridgerator not staying cool
Is the cooling fan in the back working? Does the center of fridge where your doors meet feel really hot?
Mar 28, 2017 | Refrigerators
Just bought a second hand service fridge/freezer. Plugged it in and it is not getting cold or freezing. I can hear a hum but only for a few seconds at a time. I have been assured that it works but after 2...
no check the air thats being blown by the fan in the freezer can you feel any cold air and i mean cold? if not go to the back of the fridge taKE Off the bottom panel should have like 6 to 10 screws see if the fan in the back is working  if yes see how hot the compressor(the big black thing next to the fan, sorry some people dont know what it is) see if its hot if it is very very hot like burn your hand hot you can try to cool it down with some paper towels and cold water but unplugg the fridge if its warm not so hot or cold than you need to get a 3 in 1 kit  your compressor is not turning on because the starter relay is not good and its not helping the fridge turn on the relay is very very easy to install once you get it youll have to take off the black plasticon the right or front side of the compressor there are two plastic parts that are on the compressor under the big black part ( you might not have the black plastic if not just do this step) take the plastic parts that have the wires attached to it put the kit on on the kit there are three wires with metal little parts at the tips fallow the directions and place them on the right part of the  compressor there are three metal sticks about less than an inc big and you have to put the three wires on each one FALLOW THE PICTURE black on the middle on and depending if you middle on is on the top or bottom would depend where you put what color wire if you middle one is at the top put white wire on the left and red on the right and if you middle one is in the bottom black goes on it and white on the right and red on the left but like i said fallow the directions
than you have to strip the other two wires that are left on the kit than take the two wires that you took off with the plastic parts that were on the compressor once you cut them strip the wires and just connect them to the two left over ones from the kit doesnt matter which one goes where
sorry for the long reply but this should help
if you do the 3 in 1 kit and the compressor turns on and after a while like an hour it doesnt feel cool air at all than you have a freeon leak which mean new fridge
the 3 in 1 costs like 20 dollars
good luck keep me upadated
Jun 07, 2009 | Freezers
Fridge keeps freezing everything!
you need a damper door and thermostat asm. the door that allows the cool air in is just staying open that is air from freezer and if open all the time will cause your freezing temp in refrig section you can take some tape and cover 3/4 of the grill where you feel air coming out in the frig section to help slow the air it is in the top left hand corner in the back you will feel air. should get you until you can get a repair man.
Feb 17, 2009 | Frigidaire FRS26R4A Side by Side...
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Amana ARB224RCB Bottom Freezer Refrigerator Logo
143 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
