Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Red My Red Picture Tube went out and now my picture is green.What I need to know is how much is a bulb going to run me?Plus where do I find a new one?Aswell as can I put it in myself?Thanks ASM
    Genius:
  • 1,030 Answers
Replacement of a picture tube in a itc222 chasis is one of my least favorote things to do here at the shop. average cost for a tube is around 250... replaceing the tube takes some time and the set has to be completely disasmbled. then reassemble and adjusted. i believe union electronics offer these tubes. you have to get the tube type of the tube itself there are several tube +lens combinations that have to be considered. willie at fordtv.com
Posted on May 12, 2008
The screen gets red with no picture. so i openned up the back and noticed that the green bulb or picture tube whent iut out after 5 minutes.
yes u have bad picture tube but is not the green is the red , the red picture tube id over voltege , thats way u had red picture ,
Aug 26, 2010 | Sony KP-51HW40 51" Rear Projection...
I have the same problem(redish screen with no green at all)
Does Tube Light up? with TV on Look down into Tubes and see if picture is clear or you can bearly see picture or not at all Your Projection fliuld may need changing Ive seen where tubes are still lighting but No picture showing inside tube---- Bad Coolant Fuild Call Mats for fuild and for Tube if thats what it is Call Encompass 1-800-638-3328
Oct 05, 2009 | Panasonic PT-47WXC43 47" Rear Projection...
My picture was prodominately green/red. I took the back of the TV off and looked into the bulbs. I could see a picture in the red and green, but in the blue it was barely there. Blue light was there, but...
1.) It means the Glycol in the blue tube is bad--usually contaminated by bacteria--each of the 3 picture tubes has a sealed area between the face of the tube and the lens above.
2.) If you see a picture in Green and RED but blue looks like a floodlight--the blue tube would have to be removed, drained, and the area with the Glycol washed out---new glycol added and the tube resealed and installed back into the set.
3.) This is a fairly major repair--the Glycol is very toxic---like antifreeze but much more concentrated---unless you have done it before I would not suggest it as a do it yourself job.
4.) The bacteria never affects the RED(it does not seem to like that color) and only sometimes the Green.
5.) It may not be worth repairing as most shops charge 200-300 or more for this kind of repair---not to mention that after it is done quite a lot of adjustment to the convergence will be needed from removing and reinstalling the tube.
6.) I know I am not giving you good news but you actually found your problem yourself! If you need any advice or help reply to this post and I will try to assist you.
I do this here for free so if this information helped you please take a minute to give me a vote here.
REGARDS, SD TECH
Sep 15, 2009 | Akai PTH5498 54" Rear Projection...
Tv not working
Bulb may be bad or the lamp housing is damaged from heat. The plastic housing warps causing the micro switch that tells the tv the bulb is in goes out of alignment and the tv thinks the bulb has been removed
Aug 25, 2009 | Sony Grand WEGA KF50SX300 50" Television
Picture went green. how do i change bulb??
you can get the red replacement CRT at the following link and they provide free instructions. Heres the link to the correct red for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/red-crt/cName/phillipsmagnavox-tv-parts
Apr 20, 2009 | Philips 55PP9701 55" Rear Projection...
Toshiba 57" HDTV no red in picture
I had the 65" version of that TV. Loved it, unfortunately it went bad as well. It sounds like the red tube went bad. The tube itself might sell for $400 plus. The installation will take several hours with the alignments which will need to be done. Then after all that you will start to have to worry about the other tubes starting to deteriorate. If there is any red in the picture then the tube is most likely the problem. At tat point I would say buy a new TV. The best bang for the buck if you want size and have the space for it would be the new Samsung or Mitsubishi DLP's. I just installed one at customers house. The 60" Mitsubishi is 1400 at Best Buy Good Luck Rob
Feb 27, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Red picture
Assuming this is a TV with a picture tube and not plasma or LCD; I'm afraid that your picture tube is dying on you one electron gun at a time. From what you said your green electron gun is almost totally dead and the two remaining blue & green guns aren't far behind. Eventually you'll have no picture at all and I would estimate that to be about 6 more months but whatever the time eventually it will go totally black. These blackout periods will get longer and longer. The only way to fix your problem is a new picture tube but my will probably find it less expensive to just get a brand new TV set.
Apr 14, 2008 | Toshiba 36A50 36" TV
Click click repeatedly faded then red blinking light
Go to the video menu and turn the color control to minimum. Determine if you have a black & white picture or is it green & white. If the picture is greenish, you have a problem in the screen circuit or possibly a bad picture tube. If the black & white is ok then I would suspect a problem in the chroma circuit such as a bad video jungle IC or a crystal. However, because your set had a red blinking issue prior to your existing condition I would lean towards the picture tube as the source or your troubles. You can try a simple test to determine if you have an intermittant short . Take the back off the set, and with the insulated end of your screw driver, very very lightly tap on the neck of the picture tube near the socket. If you see green flashes or hear loud snaps in conjunction with your taps or the green tint goes away, chances are the tube is the cause. If so, you might try installing an isolation transformer on the picture tube. Good luck
Nov 29, 2007 | Toshiba 36A61 36" TV
No picture coming from red lamp
Sounds like you have two differant problems. A red drive or red picture tube is bad and the conbvergence IC's are bad. To test the red drive disconnect the green picture tube socket BUT MAKE SURE THE SET IS UNPLUGGED!!Then remove the red socket and move over to the green tube. Then turn on the set. If you get the same out of the green then you have a drive problem that needs to be trouble shot for a bad componet. If you do get a picture with the red connected to the green then the red tube is shot. If you know how to read a schematic, get one and then you should have no problem troubleshooting the red drive and the convergence problem. If you dont then there is no easy or quick fix as this is a solid state set and there are no user replaceable parts inside this.,. Your going to need, for safetys sake, call in a trained tech to assist you with this repair
Sep 15, 2006 | Philips Magnavox 51MP392H Rear Projection...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
221 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
