Question about Cycling
Tronic cycle computer manual - Cycling
Singer touch tronic 2010 only sews in reverse
Here is a link to the owner's manual.
http://www.manualslib.com/manual/154331/Singer-Touch-Tronic-2010.html
Was this running ok, the poof?
There might be a reverse option on one of the selections switches.
If it has sat for a while, it might need servicing; gummed up inside.
Feb 05, 2015 | Singer Sewing Machines
Fixing the valves setting on a 125cc clipic radar motor cycle
We would check to see if this is a Honda clone or copy 125cc engine. If so use those steps and specs but only if you can not get a manual which seems unlikely.
All valve adjustments are similar on overhead valve four stroke engines. I have not bothered to look but have to ask if you did a web search for a video showing how?
I am assuming this is a four cycle engine and not a two cycle engine. Two cycle engines do not use valves. Two strikes use ports and reed valves that you can not adjust.
Next time add a good up close pic of the engine. Especially the top end.
Aug 28, 2014 | 2009 Clipic Tronic 125cc
I need a singer touch-tronic 2010 manual
I can't find any free downloads for a 2010, but I did find one for a touchtronic 2000. When the model numbers are close, very often the manuals apply to both machines pretty well. It should at least give you some info. Go to http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/TOUCH-TRONIC%202000-_E. You'll need to give them a rating of your machine, but that's all. This site and it's downloads have been checked for viruses and such, and it is a safe site. It doesn't ask you for, nor does it take any personal information.
If you are willing to pay something for the manual, leave me a comment back. I know of a lot of sites that have manuals available for a charge, and I can quickly search those and get back to you as to which ones have your manual and an idea of the costs. The ones you can download from are, obviously, less expensive than the ones you get mailed a hard copy from.
May 29, 2011 | Singer Sewing Machines
Looking for a manual
I couldn't find you a free download, but here's a threading diagram. The same site has the manual available for purchase. Hope this gets you going!
Mar 08, 2010 | Sewing Machines
I have a type 100 12 course computer that has a low battery alarm as soon as the ''auto'' button is pressed I found the rectifier diode ''D19'' was bad I replaced it and the computer worked for 1 day then...
Contact Frank Zabroski SR of Audio-Tronics he may be able to help you get everything you need
Audio=Tronics
8566670616
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 15, 2009 | Raymarine RAYTHEON S2G Notebook
TRYING TO FIND A CODE FOR MY CUTIS MATHIS TRONICS T.V. ON MY ONE
here are the codes.
Curtis Mathes 0047, 0054, 0154, 0451, 0093,
0060, 0702, 0030, 0145, 0166,
1147, 1347
You can also get the setup info here
http://www.solidsignal.com/manuals/URC-3021%20Remote.pdf
Dec 16, 2008 | One For All URC-3021 Remote Control
Cycling Logo
865 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
