Question about Toys
How do i open for battery in Nikko Stinger II boat
  • 1,498 Answers
The cockpit area is really the battery cover, it is held in with a few half twist latches.
Then you maneuver it out from behind the windshield.
Mike
Posted on Sep 05, 2010
Looking for a wiring diagram for a nikko rc truck
a more powerful battery will deffinetly increase power and speed but keep around the same voltage range 1 up wouldnt hurt it
Dec 29, 2013 | Nikko Toys
How to find the fuse box on a 2008 lowe stinger 195 boat
Depending on the item in question, trolling motor, for example, there is a fused/breaker directly running off positive side of battery. Looks like a pill box or match box. Several people have had their trolling motors quit working and this is usually the culprit. Much of the fusing runs directly of hot wire from batter to item in question. However, I will paste a URL here for you. http://www.marine-electrical.com/resourcelibrary/wiringdiagrams2.aspx
Oct 25, 2012 | Cars & Trucks
I have nikko infra-red control that has a little car that sets on the top of the hand control to charge the battery. The battery in the car is missing but on the battery tab it has irc-4 can you tell me...
I have the same little remote control car. I took my battery out to clean the terminals, and found the number on it to be 1BA1R2N120M. This is many years after your original post, but it may help someone.
John M.
Aug 26, 2011 | Nikko Toys
I have a 2006 Lowe 160 Stinger Aluminum boat. I am up grading from PD 40# to PD V2 55# which has a heavier lower unit ...Problem is this unit mounts closer to the front edge of my boat and after 6 years of...
Hey 217,
Get a sheet of 3/16" aluminum plate that is at least twice as wide as your trolling motor mount and at least 12" longer than the mount. Secure the plate to the current deck.. align the front edge flush.
You might want to radius the edges of the plate and secure it with rounded head sheet metal screws.. This will make the mount much stronger and last!!
Jul 06, 2017 | Minn Kota Powerdrive V2 Bow Mount Trolling...
I have a suunto stinger dive watch after i changed the battery the ACW stays on the screen .
open watch again and press tiny reset 'button' with a pin. That's how I fixed the same problem
Jan 11, 2011 | Suunto Replacement Strap - Stinger...
NIKKO CAR CIRCUIT DIAGRAM C1059CA DATASHEET
my Grandson got a modern mustang radio controlled car last Christmas. One to many slamming it into things, one of the battery wires came undone. The brown wire, if that helps. I need to know where it reconnects to?
Thanks
Dec 16, 2009 | Nikko Toys
1975 75 horse johnson stinger wont idle in gear or run in gear
sounds like the reverse sensor switch is stuck in lock mode
check the switch
Aug 03, 2009 | Boating
Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Jul 03, 2009 | Stinger Streamlight XT Rechargeable...
We have two Nikko remote control cars and since the batteries have gone out (and since been replaced) they no longer work. On each car, a + battery connection is plastic? is that normal?
Hi ken, if your nikko cars are dont seem to work check te conection cable maybe you need to cleened a little bit if you make it and dont work try to change the beterries again if they are rechargable or only use baterries AA
Jun 15, 2009 | Nikko Toys
Toys Logo
42 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
