Question about Kenmore 63032 Electric Dryer
Kenmore elite model 101-63032101 push to start switch may be bad, you push it in and it sometimes starts and other times you get nothing or its noisy like it is trying to start the motor but then stops. I want to check the push to start switch but can't get the back cover off, screws on the inside of the cover and can't get to them from the outside. help
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 04, 2010
Kenmore elite washer - interior light wont turn off
sounds like the door switch. put a piece of tape or something on the switch and close the door and see if taking the slack out of the switch makes it start. Or, hold the switch in while pushing start. DO NOT put any body part inside dryer when doing this.. If this works the switch needs some adjusting.. how to do that I do not know. May be a bad switch, I just replaced mine on a kenmore other week. Maybe repairclinic.com could help ya.. have model number ready when you go to the site and look at the possible reasons. Hope this helps.
Oct 12, 2014 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Kenmore elite HE31 front loader will not start but has power
This seems to be a problem in the start switch diode. If all works fine, but will not push and start and all cycles seem to work when working it manually, this is in the switch timer electronic diode is not working properly. Sometimes a code will not come up, because cycles are still working when manually changing wash cycles. There is seperate switch or electronic trigger that starts the machine, and has probably worn out or not making good contact. If you can unplug machine and then take off panel, trying spraying behind start switch with electronic cleaner to free up any possible dust or dirt. Might get lucky.
Apr 07, 2012 | Kenmore Elite HE5t Washer
I have a Kenmore Elite Heavy Duty King Size capacity Quiet Pak gas dryer. The model # is 110.76922501 and the Ser # is MTO502806. The problem I am having is that the dryer sometimes does not start when...
the push to start switch holding coil is getting weak and can no longer either make contact or drop out shutting down the unit,there is a coil that energizes to hold the switch on and when the contacts or coil get weak the unit either wont start or start and drop out/quit,you can test this switch by bypassing it and if unit keeps running the switch is definitely bad then the unit is a whirlpool produced for kenmore by the 110# you provided so you need to order a switch either thru whirlpool or sears
Aug 22, 2011 | Kenmore Dryers
Kenmore Elite Dryer won't run
make sure the lint is removed they may be some in the blower wheel if there isnt the run windeings are bad in the motor
Apr 22, 2010 | Dryers
Kenmore Elite HE4 gas dryer won't start
I had the same symptoms and it was a bad motor relay. This happened twice within 5 years.
Apr 19, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 dryer will not start
Not sure what it is but have you checked the door switch? Maybe a loose wire there? or a bad switch?
Sep 19, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
Manual might be available on line type in your make and full model. Could well be the bulb that blew. Sounds like the door switch thou i see by other postings some times the filters can cause a similer problem
GUEST. 1. start switch is faulty...oops is it eletronic?it so disregard that. 2 drum is to tight 3 motor or switch on motor faulty
smitty123. Will drum turn by hand??? Can you hear the motor hum when you close the door???
Oct 27, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 63032 Electric Dryer Logo
163 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
