Question about Whirlpool Refrigerators
Where is the defrost bimetal located - Whirlpool Refrigerators
  • 39 Answers
It is in the freezer section behind the back panel and you will have to remove it (back pannel) and the bi metal will be attached to the evaporator line above the fins.
Posted on Sep 06, 2010
Whirlpool fridge gets frost build up in freezer
This means you have a defrost problem or a bad door gasket.
Apr 24, 2016 | Whirlpool Refrigerators
I would like to get a wiring diagram for GE refrigerator defrost system (GSS25SGRE SS)
replace defrost control board or timer and inside freezer the bimetal (located in at top and rigth of the evaporator coil, test the heat element conductivity with a voltimeter
Oct 02, 2014 | GE Refrigerators
Freezer ices up
Sounds like you have a defrost problem. The parts for your defrost cycle are.
1. Bimetal part# 4387503
2. Heater part# 2315531
3. Defrost timer Part# 482493
The heater and the bimetal is located in the freezer dept. behind the back wall. The defrost timer is located behind the cold control plate in the refrigerator department.
http://www.on-timeappliance.com/refrigeratorrepair.html
Mar 28, 2012 | Whirlpool GR9SHMXLB / GR9SHMXLL Top...
Fridg. not cooling. digital display not working, frezzer thawing.
he refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Jun 11, 2011 | Whirlpool Refrigerators
How do i get unit to go in deforst
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
First Test Method:
Second Test Method:
Nov 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Maytag MSD2356AEW refrigerator freezing up
You did not clarify , if the board was changed or not . You only have 2 parts to the defrost system , as the defrost heater AND bimetal , come togather . I would start with the heater/bimetal part first .
Pt number 61006198 Heater and bimetal
Pt number 61005988 Adaptive defrost board
The bimetal , is the 1" cylinder , clipped to the top of the coils , and heater , at the bottom of the coils .
Oct 07, 2009 | Refrigerators
Refrigeradors
There are three things that are involved with the defrost cycle. There is the defrost timer, which depending on your model is either mechanical (easy to test) or is an electrical board. These are usually placed in near the controls. Second is the heater. On most models this is rare to go out except on GEs. The last is the Defrost BiMetal. This is the most common thing to go. The Heater and BiMetal are located on the evaporator behind a panel in the freezer section.
Oct 27, 2008 | Refrigerators
Temp too warm on both sides of my refrigerator
You have a defrost problem. There are three things that are involved with the defrost cycle. There is the defrost timer, which depending on your model is either mechanical (easy to test) or is an electrical board. These are usually placed in near the controls. Second is the heater. The last is the Defrost BiMetal. This is the most common thing to go. The Heater and BiMetal are located on the evaporator behind a panel in the freezer section. With a complete model number I can give you more detailed instructions on how to check each part.
Hot fridge - cold freezer
Hi. I reccommend you replace the defrost timer and bimetal thermostat. The bimetal thermostat is located on the evaporator coil. The bimetal thermostat is the most common failure. Good luck, Mack
Aug 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore upright older freezer coils frost up
the tech was telling you to put it in defrost and if ater the time you didn't hear the click the defrost timer is defective but like you are describing the defrost thermostat (bimetal) could be bad. here's a simple test (if your handy with a screwdriver) just dissasemble the panel and you will see the coil and defrost heater. if your handy with a voltmeter (please disconnect power first!) locate the two wires to the defrost element put the meter in "audible" mode and check for continuity on the defrost heater if you hear a beep it's good if it dosen't beep it's bad just replace heater w/ bimetal and your ready 2 go! email me @ hvac.tech7872pr@gmail if you have any questions
Jun 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
