Question about Kenmore Dishwashers
Dishwasher model number 363.1479580. the door will not spring back up. The spring broke and I bought a new one I can't figure out how and where to attach it pLease help
  • 2318 Answers
SOURCE: broken door spring on kitchenaid dishwasher
You will find the parts you need here by entering the model number and search for the part.
They will be able to help you with the installation as well.
Posted on May 07, 2008
uitg
Posted on May 30, 2008
SOURCE: Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Posted on Feb 20, 2009
Yazz226
  • 497 Answers
SOURCE: Replacing the spring of the door of a F&P dishwasher
http://www.acmehowto.com/howto/appliance/dishwasher/repair/doorsprings.php
http://www.applianceaid.com/lookup.html
tho not the same..shud def help
Thanks for using Fixya
Have a nice day
Posted on Mar 16, 2009
SOURCE: my ge dishwasher door cable unhooked
g.edoor falls ...I have purchased parts but now can't figure out how to repair
Posted on Aug 01, 2011
Broken door spring
This should not be hard to replace. It would have helped if you had provided the model number of the dishwasher.
You need to buy a replacement spring (best to get the pair) which looks like this item.
BAUMATIC DISHWASHER TG5 DOOR SPRING for BDS461SS
To replace you need to locate the second spring on the other side of the dishwasher and remove it. The front base plate needs to be removed first to get access to the spring anchor points. Use a screw driver or a nose plier to grab it and dislodge. Always make sure the door is shut to ensure least tension in the springs. Put the two new springs and close the base plate. MAINS POWER CHORD SHOULD BE TAKEN OUT FROM SOCKET WHEN WORKING ON THE DISHWASHER
Aug 07, 2014 | Baumatic Dishwashers
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
My magic chef dishwasher door springs broke. I need to know how to access the bottom of the dishwasher to replace the broken parts.
Open the back door and see whether the hooking points visible.
Look from the front end also to get an idea!
May 21, 2010 | Dishwashers
I opened teh door and thought i felt something hit
Murray, It sounds like one of the door springs has broken and that is why the door seems heavier and opens with much more force.
You'll want to at least make a temporary repair and order a new replacment spring to get your dishwasher working like it should and so it's safer too.
You can check to see which side of the dishwasher the spring broke, by locking the door shut (with the cycle set to "off"). Now remove the lower access panel, beneath the main dishwasher door. There are a couple of screws near the top corner edges of the panel, just under the main door and a couple more on the toe kick near the very bottom.
Once you've got the lower access panel off, you'll be able to see the two door springs, (there is one on each side). Of course, the broken one might have fallen off the spring notches, so look around and you should see it.
With the door still closed and locked, you can remove the broken spring and see if it's just the hook end that broke. If that's the case, you can reform the end hook using a couple pairs of pliers and reinstall the spring on the door and frame mounting points. You'll have to use pliers to stretch the spring slightly to get it on the other mounting point, once you've got one end on a mounting point. If the spring broke off more than 3 coils, you'll need to replace it with a new one.
You can find a replacement by using searspartsdirect.com and putting in your model number to locate a line drawing and parts listing for your particular model. You can also order a new one from them, or use the part number to get one locally, if you wish.
Once you've got the spring back on the door and cabinet mount points, you can unlock the door and gently lower the door to see if everything is working properly. Once you've opened and closed the door several times, you can reinstall the lower access panel and you're back in business.
I hope you find this Very Helpful and best regards!
Oct 24, 2009 | KitchenAid Dishwashers
Door is broken
Hello Hickin! It would appear that one, or both of the door springs which act as a counter-balance for the weight of the door, have broke.
To confirm this and get at the spring(s), close and lock the wash compartment door and use a screwdriver (might be a 1/4" or 5/16" nut driver instead) to remove the lower panel.
Once you have the lower panel off, you should be able to see the door springs on each side. You'll probably also see part of the broken spring lying in there too. If the door spring broke near the end by the hook, it is possible to TEMPORARYILY bend the spring with a set of channel locks and pliers to form a new hook end, that you can attach to the door clip. If the spring is broke near the middle, you'll need to get a new one.
Regardless, you'll need to locate the model number for your dishwasher and obtain a replacement spring ASAP, as the temporary repair will only work for a short while before the spring breaks again.
You might want to try Fagor at their site to see what the part number for the replacement spring is. http://www.fagoramerica.com/
The other option with your model number is to try the Sears part web site, which shows a line drawing and parts list for most applianances.
http://www.searspartsdirect.com/partsdirect/index.action
This repair is relatively easy for anyone to undertake and you can save yourself the cost for a service tech's labor charges, plus the trip/house charge they normally tack on.
Oct 12, 2009 | Fagor Dishwashers
GE GSD900L-02 Door spring cable broke
Get 2 of the same springs part # PS259673
DOOR SPRING (YELLOW) (Heavy Duty Door Spring)
Sep 12, 2009 | GE Dishwashers
Door spring broke
What is the model number? If you go to this website, you can see what part to order and how much.
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Jul 30, 2009 | KitchenAid Dishwashers
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Nov 23, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Dishwasher problems
Can't say for certain, as you don't list a brand or model number, but most have the springs on each side of the outer tub. (you will have to pull dishwasher at least partway out of the cabinet to access them) Some have a set of springs behind the access / toe kick panel. (DW removal unnecessary for these)
Sep 01, 2008 | Dishwashers
Dishwashers Logo
49 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
