Question about Emerson MW8987B/W Microwave Oven
The tray doesn't spin - Emerson MW8987B/W Microwave Oven
  • Emerson Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 04, 2010
Is the center arm on the floor of the microwave a replaceable part?
First of all thank you for your model number. To Answer you question: A - yes it can be replaced but will be hard to locate as this was discontinued. B - maybe if all the parts are there you may be able to glue it back together. C - If you control panel has a turntable off button you can switch it off, if not you can unplug the turntable motor located under the unit with two wires going to it. Just unplug, don't cut any wires. I hope this helps
Apr 18, 2016 | Jenn-Air JMV8208BAS Microwave Oven
I had a power surge in my house and my EMERSON 900W MICROWAVE OVEN MW8999RD control pad is not working. The lightbulb works and the tray spins slowly when I open the microwave door. However, nothing
I hope it's still under warranty. Think about getting a replacement, and about next time: Get a surge protection device between the oven and the wall plug! I have suffered from power surges in my house as well, and a surge protector is the only cure.
Dec 07, 2014 | Emerson Microwave Ovens
Turn table in microwave wont turn
Repairs are expensive. New microwaves are cheap. But you don't have to spend a dime on either. If your microwave turntable stopped spinning, here's an easy way to try and fix it. And all you need is some warm, soapy water and your own two hands. You don't have to be an appliance expert to troubleshoot a seemingly broken microwave turntable. You might find that all your little Zappy needs is a checkup and a good, thorough cleaning. If you follow these steps and find that your microwave still isn't turning, it probably means the motor has spun it's last spin. Then it's time to retire old Zappy. Unplug the microwave. Safety first, kids. Remove the glass tray and the circular turntable guide. Wash them both in warm, soapy water to get rid of anything stuck. Pay special attention to the rollers on your turntable guide, making sure they're able to spin freely. Clean the internal cavity. Make sure to check your microwave's center cavity to make sure it's free of movement-hindering (and gross) leftover food. Check that the drive bushing is working. Make sure that the drive bushing, the plastic mechanism in the bottom of the microwave's interior that the glass tray turns on, isn't worn out or split in two. If it is, you'll need to have it replaced. Put it back together. Put the turntable guide back into the circular groove. Place the glass tray turntable over the turntable guide and onto the drive bushing. Adjust until the drive bushing should fits perfectly into the grooves of the glass tray. Test it out. Zap a mug of water for a short bit to see if you fixed the problem. Do not run the microwave without anything in it.
Aug 05, 2012 | Microwave Ovens
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
When we plug our microwave up it lights up and the tray spins but it isnt producing any heat. What is the problem?
You have a bad door switch or micro-switch. You can do a simple continuity check to be sure which switch is shorted out.
Dec 07, 2010 | Microwave Ovens
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Panasonic NN-T990SA mfg 2002 Door opens, tray continues to spin-light on-fan on--not cooking.
call the toll free number for the product, service centre might assist, I would not use until fixed
Sep 03, 2009 | Panasonic NN-T990SA Microwave Oven
Table not spinning
your oven is not spinning,when u put some load,either the motor which makes the spinning is not picking up the load,so u get the motor serviced or change the carbon brushes which comes in front of the armature of your spinner.
Apr 02, 2008 | Dacor DMT2420SS Microwave Oven
Most models allow you to turn the turntable off and on via the control panel. Check that setting in the display first.
If that's not it, then the motor had probably failed.
You can find handy exploded view part diagrams and order parts at http://www3.sears.com (the 3 is correct).
Something looks wrong with the posted model number. Is that right??
Nov 25, 2007 | Kenmore 62702 Microwave Oven
Emerson MW8987B/W Microwave Oven Logo
57 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
