Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Dishwasher suddenly stopped working. doesn't do anything when you push the buttons. the lights don't come on. It's as if there's no power but nothing has changed in the kitchen. everything else works fine.,
markevans
  • 148 Answers
SOURCE: kenmore dishwasher model 665 motherboard
relay or sensor
Posted on Dec 21, 2007
  • 71 Answers
SOURCE: frigidaire dishwasher not working
check electrical conectors to dw
Posted on Dec 21, 2008
SOURCE: there is power to the kitchen aid dishwasher but
Try selecting another wash cycle
Posted on Oct 07, 2009
  • 70 Answers
SOURCE: My GE dishwasher, when i push the start button nothing happens.
1)check any fuse had gone in electronic board.
2)check the input voltage to pcb.(normal)
Posted on Jan 08, 2010
  • 457 Answers
SOURCE: Bosch SHE43M was running when a pipe broke under
water is in the base and the float switch is activated. you must remove the water to deactivate.then hit the drain and cancell. let me tell you a quick joke .Im a old bosch tech and i had a call with the same problem. as soon as i got there i notice mouse droppings.the customer had a tech come by and told her she needed a circulation pump amodule the whole thing.wrong!!! what had happen was a mouse had made a mouse bed with the white packing foam and pulled it under the float in the unit. so the unit thought it had water in base and it went into drain mode . I removed foam and problem solved.
Posted on Feb 26, 2010
Testimonial: "Thanks for the great advice. Unfortunately, you didn't see it in time. We ended up paying for a new pump as Sears indicat. Will remember next time."
Dishwasher Asko 1986 suddenly stopped working
Also is mainly a control board's
Did you have a power outage or power surge?
Need model
Oct 08, 2016 | Asko Dishwashers
Quad wont start
check starter solenoid
should have power at the little yellow ( guessing color ) when the button is pushed
should have ground at the black wire ( if applicable )
yes, solenoid is bad
no, backtrack to the push button
does it have a key switch by chance ???
Dec 31, 2013 | Toys
Kitchenaid dishwasher 577
Does it work though? If the light is staying on after you cut power then maybe a genie is living in there :)). Other than that it could be a bulb with bad or loose connection. I do know those touch pads behave weird if there was a power cut/surge. Mine did that bit it still works. I'm just waiting to see if a light blows or if some other short happens. Anthony
Jun 15, 2013 | KitchenAid Dishwashers
I have a maytag dishwasher model mdbh985aws1that stopped working. The controls buttons on the left light up when pushed but the buttons on the right (including the start button) do not work. Any ideas on...
The CONTROL PANEL and/or ELECTRONIC CONTROL BOARD are broken. Unless you are good with a multimeter and wiring diagram just order both and send back the parts you don't use.
Aug 26, 2012 | Dishwashers
DIshwasher stopped during wash and won't run or drain.
Sounds like a drain motor startup capacitor, or stuck pump. Try disconnecting power and turn the water pump manually. Some disassembly required. Then after a few good hand spins replug and try again.
Mar 05, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
Jan 08, 2010 | GE 24 in. GSD4000J Built-in Dishwasher
Dishwasher stopped. no lights, no nothing
My Kenmore just did the same thing, I verified power to the unit.
Jun 26, 2009 | Bosch SHU3306UC Built-in Dishwasher
Smeg Dishwasher ST 663 sometimes won't work
My dish washer stops after i5 minutes, don't know what the problem is, water is going in but just suddenly stops, i changed the hose but still the same. Any help welcome
Feb 22, 2009 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
LG dishwasher LDS5811ST
The problem with the dishwasher acting haunted is probably the main controller card. If you don;t have an extended waranty, know that LG will cover the parts for free through 24 months but after 12 months, the labor will be charged.
Nov 01, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Kenmore Ultra Dishwasher. Model 665.15772990
There should be a button on the machine with a padlock symbol. Hold it down for 4 seconds to unlock it. If you want to lock it again, hold it down for 4 seconds to turn it on.
Jun 01, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
87 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
