Question about GE Profile PDS22SBSRSS
Items are freezing in the fridge portion. - GE Profile PDS22SBSRSS
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 05, 2010
My Lg fridge Model # LFX25980ST is freezing my food in the lower portion of the fridge
Lower the number on the temp dial or replace the thermostat.
Jan 03, 2017 | LG Refrigerators
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
Why is most everything freezing in my fridge. I have a fridgidaire elite.
Have you tried adjusting the thermostat level down several numbers to see if that solves the problem? It should be on the very top of the fridge portion when you open the door. Sometimes they are located in the freezer but most times the adjustment for fridge is in the fridge and freezer adjustment is in the freezer portion. If that does not work then you could be getting low on freon and it could be super cooling just before it runs out of freon. Try the adjustment first.
May 06, 2012 | Frigidaire Refrigerators
My Frost Free Fridge-Freezer has a problem. Upper portion, freeze all the fruits and vegetable, and lower portion not freezing any poultry meat etc. We have contacted a local dealer, and he need spare...
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check the cold control and the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout .....
Aug 08, 2010 | Refrigerators
Fridge freezing items
Most cases bad temperature control, some refrigerator has a damper control by the temperature control in between freezer and refrigerator, if the damper stays open, it will freezes contents.
Mar 07, 2010 | Refrigerators
Refrigerator portion not getting real cold, freezer is ok.
I you have set the adjustment (if there is one and should be) on the fridge side to the colder setting, there may be an electrical issue with the control.
If there is not much in the fridge and you set it too cold, items will freeze.
Use a thermometer and make sure you have some items in there, test the temp.
You can just use a bunch of the ice pouches from a cooler to fill it up for this test, then see what it says the temp is, also check the manual you have or can get from the internet. It should tell you optimal temp.
More info on fridge is helpful, i.e. model number, mfgr date and so on.
Aug 31, 2009 | Whirlpool Refrigerators
Freezing eggs in fridge area and freezing produce in crisper
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
GE Profile PDS22SBSRSS Logo
85 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
