Question about Magic Chef Freezers
Runs but wont cool - Magic Chef Freezers
  • 384 Answers
Dear sir/madam
i think your freezer have short gas problem there can be possible any leakage so please contect to your service technician for refill the gas .
thank you
please vote!
Posted on Sep 05, 2010
How do i get my condenser fan to stop running. it is cooling fine but won't shut off unless i shut it off.
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Oct 09, 2014 | True GDM-47 Refrigerator Merchandiser -...
Samsung refrigerator wont cool down
JUST ROTATE YOUR THERMOSTAT TO THE MAXIMUM AND WATCH IF STARTS COOLING THEN ADJUST THE THERMOSTAT TO YOUR REQUIRED LEVEL LATER ON. iN CASE IT DOES NOT START COOLING CHECK THE COMPRESSOR WHETHER IT IS WORKING, IN CASE YES THEN THERE IS NO GAS IN IT
Sep 29, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
True gdm35 evaporator fans not working?
change the fan motor, if the fan dont wonrk wont spread cool air
Sep 18, 2014 | True Display Refrigeration GDM-35F
My amana Deepfreeze runs but doesnt cool
sounds like bad capacitor wont let compressor start up if voltage going to it but not going out replace
Aug 16, 2014 | Freezers
Compressor runs but wont cool
Make sure the compressor is running it should be vibrating and get warm after a few minutes. If it is indeed running the smaller tube to the compressor should be getting warm if not it could very well be the compressor has stopped pumping. If the fans are not running they could be controlled from the control board and will come on when the sensors on the evaporator get to a certain temperature. I does sound like the compressor is the problem.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Samsung refrigerator not cooling
Sounds more like compressor failing to pump than board fault
Frig runs but wont cool in freezer or frig area
Either your compressor is bad or you had a leak and lost the refrigerant.
Feb 24, 2010 | Frigidaire Freezers
Freezer wont cool
This problem could be cause by a few things. Can you tell me if your condenser is clean? If it is dirty, the heat cannot be rejected. Will you feel the large copper line going to the compressor and tell me if it is cold to the touch? If it is not col and your compressor is running you may be low on refrigerant. Also, is the evaporator frozen over? If your evaporator is frozen over you might be low on refrigerant, or you evap fans may be out.
Feb 15, 2009 | Traulsen Freezer G22013 Freezer, Reach-in,...
FREEZER
If there is no cooling on the evaporator or only partial cooling then you probably have a gas leak, or the compressor is not pumping correctly. Either way you would need a professional diagnosis. Either way not a good scenario. Hope this helps.
Aug 07, 2007 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezers Logo
114 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
Offbelay
Level 1 Expert
AJMAL KHAN
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
