Tried brand new dvd and still comes up "no play"
How do i clean the lens and where is it.thank you
  • Penny Dafoe
    Penny Dafoe May 12, 2008
    thank you very much,are they expensive?
  • 35 Answers
I recommend you to get a lens cleaning disk its easy to use without much hassle.
Posted on May 12, 2008
  • raj narayan May 12, 2008
    hi calpen, that doent seem expensive if you are not taking it to a repair man does it?it wont cost you much.just a few $more than a conventional dvd.have a nice time.
Our daughter pulled on the tab inside the dvd player by the lens. Now the dvd player shows "no disc" when trying to play it. Can we get it fix or fix it? thanks
try cleaning the optical lens. if nothing happen just bring it to the local repair shop. but sometimes it is better to but a new one to replace the optical lens because it was expensive as a brand new dvd player... ty
Jun 23, 2011 | Sony DVP-FX750 Portable DVD Player
My Onkyo DVD/CD Player CP704 plays CD's with no problem, but DVD's are a problem: I get "loading" but does not play and I get "no disc" on many occasions. What gives, any solutions? Thank you.
Laser Beam could be dirty, use disc cleaner or clean the eye beam on the laser pickup but the Laser ickup could also be bad, Mats has them
1-800-628-1118 First try Cleaning Eye Beam.
Jun 02, 2010 | Onkyo DV-SP404 DVD Player
the answer is "YES". You can replace the laser (lens), that's the only option you have left since cleaning the laser (lens) did not solve the problem. This shows that the laser (lens) is dead. You need a brand new one.
So go ahead and replace the laser unit, its a very good idea.
Good luck.
May 28, 2010 | Teac DV-L800 DVD Player
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Laser lens not reading disc.The disc spins,but i get no video,or audio when dvds ,or cds are played. Cleaned the laser lens didn't solve problem. Figured the laser pick up has played out.Can anyone help me...
faulty lens you will need a replacement depends on brand and price sometimes its cheaper to buy a new dvd player, i know its a throw away society but thats just the way it is
May 07, 2010 | Televison & Video
Dvd player will not play movies
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is the cause of he problem and not battery.
The lens reads the files/data on the disc inserted into the player and once the lens is weak, there is no way it would load Cd's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all CD's with no problem at all.
Good luck.
Apr 22, 2010 | Supersonic SC-299TDVD
Pansonic e 85h won't play recorded disc or finalize recorded discs also unable to play previously finalized discs, hdd is working and recording fine, what could be the problem on this dmr e 85h panasonic...
The symptoms sound like the laser needs cleaning adjusting or replacing by a qualified technician. If it is under warranty then you can return it. The only other thing youmight try is to open it and gently clean the laser lens with a q tip and a drop of alcohol if you know how. Otherwise get it professionally serviced.
Kind Regards
Mar 12, 2010 | Panasonic DMR-E85H DVD Recorder
Can not play disc
You can try a lens cleaning kit. If it is the kind that comes as a disc all it will do is lightly brush the lens which may not remove all the debris. If you disassemble the player you can easily get to the laser lens. It will usually be fairly accessible once you remove the DVD case. Sometimes it may be located within another box that needs to be disassembled before you can gain access to the laser. The laser unit will be located on a rail system and will have a small clear lens about the diameter of the eraser on a pencil. You can gently clean it with a cotton swab and lens cleaner or rubbing alcohol works just as well. Try that first before buying the lens cleaning kit or replacing the player.
Jan 07, 2010 | Sony DVP-NS715P DVD Player
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
DVD trouble
You can try and clean the lens with a lens cleaning cd/dvd.
Jul 04, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
