Question about GE GTS18 18 Cu. Ft. Top-Freezer Refrigerator with Upfront Illuminated Temperature Controls & Spillpr...
I have a gts18eb ( i believe thats the model #) GE fridge/freezer with freezer on top. lately, the freezer doesnt get cold enough to freeze and every now and then i find some meat is defrosting to the point its a little squishy. Also some stuff in there gets a find layer of frost on it. the fridge also gets some water dripping inside it from the freezer which is molding some food in my fridge. I am guessing it is a defrost issue? I just took the back panel in the freezer off and noticed a big buildup of ice on 25% of the evaporator coils so I blow dried it and soaked up the water. I just plugged it back in and loaded it back up. Just want to know what causes this and how can i permanently fix it. Thanks for all help!!
  • 958 Answers
SOURCE: Evaporator coils frosting up
the frosting of the back compartment of the freezer indicates that the ice builds up at the evaporator ( the coil that cools). the system is supposed to melt the ice after a particular time interval for a period of time in order to start another cycle. im not sure if that model uses the electronic timer which you can not manually adjust to see if it is heating up on the heating mode. you would have to check three things. one is the defrost heater itself if it has continuity. another is the thing that we called thermodisc . its a part of the heating circuit where it cuts the heating current after it senses that the temperature of the evaporator is way up the thaw temperature. it is normally connected in series with the defrost heater and it is attached to the latter part of the evaporator tube. lastly which as i have told you is the timer. if its a mechanical timer, then probably it is not going to the heating mode. another is the electronic timer which is very hard to trouble shoot. you have to really observe the refrigerator how long it is running and if the compressor is stopping and the heater working by looking at the back if water is draining after a few minutes the compressor stop. as i may add, as you have said it is winter there, a thermostat setting could be an issue. the heater could probably not cope up with the coldness of the ambient temperature in which i may suggest to put the thermostat setting to the lowest setting on the knob. i hoped i was able to help....drcool
Posted on Feb 05, 2008
SOURCE: GE GSL22JFPH BS refrigerator, coils icing up
I'm in the process of fixing the same problem on a GSS22JEPDWW right now. There are several parts in the defrost circuit that I can tell:
1) Defrost Heater
2) DefrostThermostat
3) Temp Sensor (Thermistor)
4) Main Control Board
I've replaced the Defrost Heater (remove back panel of freezer section - it's a stainless steel bracket that has a glass bulb in it) and it still doesn't work. The main control card provides power to the heater 4 times every 24 hrs for 25 minutes or so to defrost the evaporator coils. If all items are working, you'll see water in the drip catch at the bottom inside of the freezer compartment. Better yet, pull the refer away from the wall for 24 hrs and check if water is gathering below the plastic drain on the right rear of the refer in the pan. The water drips into a pan and the fan for the condensor coil evaporates it. Go to the www.ge.com website and look in the service section to find the parts diagram for your refer. You can then get a part number to buy the parts you need from a local parts store or the Internet.
I just bought the thermostat a few minutes ago and will try that next. Heater was $37, thermostat was $15. Sensor is about $20 and the control card is $140 (you can find on line for $95). I'm going down that path. If none of this works, it'll be in the dump in a week.
I've learned on-line GE refers are bad news. The control cards can fail repeartedly, althoough mine has worked for over 4 years. But, I won't ever buy another one since refers should last at least 15 years in my book. After $200, it doesn't pay to throw more good money after bad. I'll keep you posted on my results.
TM
Posted on Jun 25, 2008
  • 1122 Answers
SOURCE: Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Posted on Nov 30, 2008
  • 61 Answers
SOURCE: GE side by side refrigerater is not cooling on one side.
sounds like ayou could be having a problem with the defrost system pull the back cover off and you will see a metal bracket about half way up the coils and one at the bottom some models just have the one at the bottom these are defrost heaters check and see if one is burned out if so defroset replace heater and you will be ok if heaters are good check at the top of the coils there is a small round thing cliped onto one of the coil lines with 2 wires coming out of it this is a defrost bimetal or defrost thermostat now for this check the bimetal has to be cold and you need an ohm meter it is a simple test when cold it should read close which with and anolog meter will peg the neddle a digital will read 0.0 -0.2 this means this part is good if the needle does not move or you get no reading it is bad replace it now if the heaters and bimetal are good there is and evaporator thermister also located on the evapoator it is a small white look like a small bulett it could be sending the wrong information to the mother board this part is about 10.00 and the mother board on theif you still have a problem im afraid to say you mother board is bad replace it and you should be good to go with out all the snow it runs about 150 - 200 dollars depending on who you get it from.
Posted on Jan 20, 2009
jumptrout51
  • 3361 Answers
SOURCE: Frost free failure on a GE fridge. Removed access panel to freezer section to find evaporator coils crusted in frost. Cannot locate defrost timer and cannot locate any repair manuals online. I'm not w
The defrost timer is electronic and built in to the main control board on the rear of the box.
The defrost heater and defrost thermostat are the most likely culprits on this brand.
They are in the freezer above and below the coil.
They usually come as a set.
Posted on May 24, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Freezer not freezing. meltdown?
clean the accumulated dust from under the fridge. The fridge doesnt get cold enough, the freezer gets too cold, it needs air to pass through, grab the dust, or vacuum so that air can pass across the coils
Jul 07, 2014 | GE Profile PSI23NCR Side by Side...
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile atrica not getting cold enough
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My refigerator and freezer are not cooling enough
You could call for service. It is commonly possible that there was a loss of gas, or the thermostat is defective, or the compressor is weak. The refridgeration service man should be able to check for all of this.
Jerry G.
Apr 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fridge not cold enough
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting, YOU CAN TRY turning FREEZER CONTROL To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side.
Sep 25, 2007 | Samsung RS2534 Side by Side Refrigerator
GE GTS18 18 Cu. Ft. Top-Freezer Refrigerator with Upfront Illuminated Temperature Controls & Spillpr... Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
