Question about Alto-Shaam (SHOALT610GASMLSNAT) Oven
Where can I find a parts diagram for an alto shamm 7.14 esi. I had a couple parts fail/burn up witha power surge. I talked to a rep and ordered what i thought was the right parts but they were wrong
Owen fan always run, after plug owen in. How to stop it or reset it?
Your Fan thermostat has failed, now the cooling fan will run forever trying to cool the broken part... Look for the thermostat in the wiring diagram that is with the oven, meter it for continuity, and if it fails, use the model number to order a new part from a local part store- your model number represents nothing here in America or I would tell you the part #! Range Stove Oven Thermostat 318578506
Jun 25, 2016 | Electrolux EOB6630 Ultrafan Electric...
The time display has gone blank. When I switch on temp dial the red oven light flickers. When I switch on fan dial nothing happens
Assure full power is available to the unit(220 volts-not 2 times the same 100 volts). Depending on the model, and age of the unit, the circuit board behind the clock is failing or has failed. The timer board directs timed power for the oven, shows the times, and may have other features. Any elements are usually directly controlled by the knobs without going thru the timer board. When the timer display disappears and stays blank no matter what you do, even turning the breaker off and then on again , then power thru the board has failed. This could be caused by mass failure of the board(burned out-burned parts-vaporized parts) right down to a couple simple components that have failed due to age and don't pass the power onto the circuit.. High voltage is present and any troubleshooting should be done by a competent person for that task. Be safe.
Apr 27, 2015 | Ovens
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
E-21 is on the panrel of our alto shaam, what do we do to clear it?
Try turning the power off and back on a minute or so later your clock may reset
May 29, 2011 | Alto-Shaam (SHOALT610INMLS2082401)...
Maytag oven mer577oaw won't heat above 105 degrees
Your thermostat/sensor has failed
CLICK HERE to see/order the part.
it is #5 in THIS EXPANDED DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Ovens
Dead trivection oven by ge JT9300h1ss
This model has issues with the power input controller board, usually caused by surge following a power failure... board is $285 from GE plus $90 or so to install after paying a $100 service call. Replacment part is special ordered and generally takes a week or so.... have 2 of these ovens... ask me how I know.... LOL
May 30, 2009 | GE Profile JTP18 Electric Single Oven
After a power outage the oven stopped working and CAL appeared
You need a surge suppression device on the oven...It is hard to do that so were do you put it. On the main distibution panel.
Not a lightning Arrestor. It is not a Surge suppressor. A lightning arrestor only keeps the wires from burning up, and a surge suppression deivce not only does that but keeps your stuff from blowing out like it did.
PTS-240HUL-L will cost you $268.00 and I have one in stock.
A electrician will cost you $50.00 in a non-union state and in a Union state about $100.00 to do the install...if you sweet talk him into it.
www.storminprotection.com
Dec 11, 2008 | Thermador C272 Electric Double Oven
Oven not working
In this case, I would check the following:
  1. Make sure the oven is receiving power. Turn the power off and on at the circuit breaker.
  2. Pull the oven out of the wall and inspect the control boards. Look for burned areas. The power area could have burned out or the control card probably burned out.
  3. Personally, I think that in this case, the are that the whole computer card will need to be replaced. It runs over 100$ in parts.I think this because it's happened twice to me -- once when we had a power surge in the house, another time when I simply replaced a light bulb in the oven.
I hope you will post back what the actual solution was.
May 19, 2008 | Fisher and Paykel AeroTech Double OD302...
Have an AMANA AOGD2750 oven blew electronic board
You will need to replace the ERC module Pn 31799201: expensive $199
May 06, 2007 | Amana AOGD2750 Gas Double Oven
Alto-Shaam (SHOALT610GASMLSNAT) Oven Logo
47 people viewed this question
Top Alto-Shaam Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Alto-Shaam Oven Expert? Answer questions, earn points and help others
