Question about Garden
WON,T START UNPLUG CUTOFF WIRE AND COIL IT CRANKS BUT FLOODS OUT NEED WIRING DIAGRAM
  • 10,865 Answers
Hello. All of these diagrams are brand and model specific so please get back with the brand, and model of your mower. You could also purchase the repair manual at http://www.tractorpartsinc.com/tractor_service_manuals_8_ct.htm
OR you could go to the dealer and ask them for the wiring diagram. They will have access to it on their computers. J.
Posted on Sep 08, 2010
  • 2,299 Answers
There are some wiring diagrams online. But need to know what kind of mower or garden tractor it is. Usually it is a safety switch. On most it you take the top cover off you can find the coil. The coil is interrupted when one of the safety switches are not made. There is a safety switch on the seat, the mower deck engage, and the brake pedal. But if you take to cover off and find the coil, it should have a green wire going to it. If you disconnect this wire then it should start. But when you do this it will start without any of the safety switches made.
Posted on Sep 04, 2010
  • Rodney Clark
    Rodney Clark Sep 04, 2010
    If you unplug the wire on the coil. Remove the spark plug and see if you are getting spark. I am sure you know how to do this. But in case you don't I will explain. Take the spark plug wire off and remove the spark plug. Insert the plug back in the the wire. Put the plug where it is touching a good ground or metal on the engine. Crank the motor over and see if it sparks. If it doesn't spark then it is a bad coil. The coil is what produces fire from the magnets on the flywheel. When the green wire is shorted, then it shorts out the coil. So if it still won't start with the green wire removed off of the coil then it has to be a bad coil. I know that you asked for a wiring diagram, but this should simplify things a little I hope. If it does start with the coil unplugged then it is a safety switch. The seat switch is the easiest to check and is usually the one that goes bad. You can find it under the seat. Unplug it and take a piece of wire and stick it in the connector. Then see if you get fire. The brake switch is usually tricky to get to. But if you let me know what kind of mower it is then hopefully I can get you the diagram!
2008 VW POLO CLSSIC 1.4 ENGIN LIGHT DOENST APPEAR AND THE CAR WON,T START CAN U PLEASE HELP ME BEAUSE I UNPLUG THE COMPUTOR BOX FOR HOUR SO WHEN I PLUG IT THE CAR WON;T START
You have no communication with your ECM, it could be the ECM itself or a Can-bus wiring problem. You will have to check continuity on your CAN wiring from the ECM to the gateway, you will need wiring diagram. Should be able to find those on the internet or some parts stores offer them free
Feb 11, 2014 | 2000 Volkswagen Beetle
2001 honda s2000 cranks but won't start. Just
see the diagram attached. by pass the starter and try IT. God bless you
Jul 18, 2013 | 2001 Honda S2000
1990 Dodge Ramcharger won't start. Battery output 12v, voltage across coil terminals 6v, voltage output at coil port to coil wire 6v, voltage of coil wire output to distributor 6v. Engine will c
There should be a small white ceramic block on the firewall - this component cuts the battery voltage from 12 to 9 volts for the coil and ignition system. It has 4 wires and is called a ballast resistor.
You may need a book with the wiring diagram to be able to test it. You should have battery voltage going in and something like 9 volts coming out.
You can also run a wire with a fuse from the battery to the positive side of the coil to check the system. Disconnect the factory wire from the coil first.
Jan 27, 2013 | Cars & Trucks
Wiring diagram holden nova 1994
Hi sounds like the ignition switch is the problem if it will bump start there is nothing wrong engine side, hope this helps
Aug 04, 2017 | Cars & Trucks
No spark cub cadet 933E changed plug still no spark motor cranks fine
you may want to check the coil. under the coil there is a wire (kill wire) unplug it. try to start it, if it starts you have a bad wire somewhere. if it don't the coil is bad and needs to be replaced.
Nov 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
We have a 1993 Mitsubishi Eclipse 1.8 and we replaced the interior, dash, and instrument cluster. Everything was fine except the instrument panel would not light up. Connections were checked and a few were...
Found this wiring diagram. Voltage for the coil comes from ignition switch, the ignition power transistor/ignition module controls the ground for the coil. My info says you crank and cam position sensors are built into the distributor. Sorry, I know very little about a Mitsubishi, I can't help you diagnose.
May 11, 2017 | 1993 Mitsubishi Eclipse
Wiring diagram for a stihl saw ST400
There is no diagram. it is a simple system the coil for the plug has a kill wire that runs up to the thumb switch.
page 31 of the service manual shows the connectors.
Make sure the wires are not rubbed through.
I am a Gold certified Tech for Stihl. Feel free to ask any other questions you might have.
Jose
link to ts400 manual
Jan 12, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
90 f-150, 302, 5-speed, floods when trying to start, ...
It sounds like your automatic choke is set to rich you may want to try and back it off a little
Mar 19, 2009 | 1990 Ford F150
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
