Question about Eaton Air Tools & Compressors
My ht-134 dry got hot and shut down.wont take password to reset error?help
  • cvcd Sep 05, 2010
    MY compressor is a Eaton 30 hp rotary screw model ht-134 dry.Buit March of 2009 and has about 1500 hrs.I insatlled it used about a week ago.I have a very poor manual that I downloaded.When it shut down, on the panel there is a diagram of the system and there was a red light with a tone on.Staff let ot cool down and turned the power off to try and reset.The light/tone went off but compressor did not come on.On the screen it says....STATE...emrg stop..near..History fault says T-High...W-6...When I go to operation mode...on/off-near...load-auto...com mode-prohibit...com add-001.I have tried to go further in the menu to reset but i cant get it to take the password.I change the **** to 8 as i go and have hit every button after it is enterd but wont take.My name is Jason and I dont know how this works but my #604-302-2668 or send yours and I will call you.
  • 12,061 Answers
Unfortunately what has happened is the main controller has suffered a fairly major problem. Most likely a spike, or a surge from the Power Grid, is the usual cause, but often they just spontaneously fail especially if after getting too hot. It sounds as though the Power supply and or the main microcontroller board. As this is the only things that can case these symptoms you describe.
You are going to have to call a professional, as the replacement parts will only be available to authorised service persons.
You need to contact Eaton, and ask for a referral to an authorized repair agent, when they attend, ask for a "Quote" before allowing any repair work to proceed. This way you can make an informed decision as to what to do.
Posted on Sep 07, 2010
  • 10,865 Answers
Hi. Please reenter your issue giving more information about your product. HT-134 is a common name and it does not identify your piece of equipment. J.
Posted on Sep 05, 2010
LG 50 PS 3000 tv will not turn on. Flashes a picture then turns itself off
Since your TV comes on and shuts off, the possiblity of the main power developing a fault on switch on to shut off as the error amp is asking it to do so.. Please check for any failure of capacitors in the HT section. use a multimeter and test voltage on switch on. make a note and test after it switches off. you will slowly arrive at the point of trouble. look for dry solder joints. use a good iron to carefully solder all joints suspected to look mushy. check the connectors of the HT drives to the panel. there could be fault in the connection resulting in slow build up and causing the error amp to react to shut off. Hope my advice helps. Good day
Jul 12, 2010 | LG Televison & Video
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
My dvd home theatre system ht tx75 keeps shutting down
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
30 GB Ipod not shutting down
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Nov 26, 2007 | Apple iPod MA446LL/A MP3 Player
Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Jul 02, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Air Tools & Compressors Logo
66 people viewed this question
Top Eaton Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Eaton Air Tool and Compressor Expert? Answer questions, earn points and help others
