There is a spring loaded pulley right on top that you can put a wrench on and turn it to loosen the pulley. Put the belt on all of the pulleys except the spring loaded pulley. Then get your wrench on the spring loaded pulley. I believe it is 18 MM. Then turn the wrench to loosen the pulley and slip the belt on.
Use a 3/8" ratchet to insert in the square hole to release the tensioner to apply the belt onto it
