Question about KitchenAid Dishwashers
We have a kitchenaid dishwasher, kudi22ot3, installed in 1992. It is not cleaning dishes even thought the tub is getting water, and we've run dishwasher magic through it a couple of times. The dishes will get clean for a few runs, and then will stop getting clean. Is it time for a new dishwasher or can this one be fixed? Thank you.
  • 10,515 Answers
There are 6 major reasons that could affect the cleaning.A nice guide you could follow is :-
http://www.partselect.com/dishwasher+dishes-not-clean+repair.htm
Other than this, you need to check the pump. Make sure that it is not clogged.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 04, 2010
Dishes won't come clean
Check your water inlet for the right pressure and then the water float valve for the right amount of water in the tub for washing. The tub has to have the right amount of water in it to pump it up to the top. It is also possible that the pump has debris in it that is restricting the flow. Clean out the screens and check the bottom of the washer tub for debris at the pump inlet. Use white vinegar to clean out your washer. Start your washer - open the door and pour in a lot of vinegar. Let it run for a few seconds and stop it. Let the vinegar work on the scale and debris. Start and stop it several times during the day - not completing the wash cycle until in the morning - after it has sat with the vinegar 10 -12 hours.
Mar 03, 2014 | KitchenAid 24 in. KUDP02CR Built-in...
I have a kitchenaid dishwasher that doesn't dissolve even liquid soap. At the end of the cycle there is hard compacted soap residue that ends up blocking the holes where the water shoots out and there are...
Try getting some calcium, lime and rust remover. Follow the instructions on the bottle and run the dishwasher empty using only the CLR. Check your incoming water lines for calcium or lime build up.
Sep 17, 2013 | Dishwashers
My kitchenaid dishwasher is not cleaning as well as it use to. The dishes do not "feel a finished clean". It's like it's not rinsing all the soap off and they're just not clean...
Hi wesalado,
Please follow my Tip below on some hints on how to keep your Dishwasher in tip-top shape:
DISHWASHER NOT CLEANING PROPERLY ANYMORE...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 03, 2011 | KitchenAid Dishwashers
Kitchenaid dishwasher will not fill. Water does
First make sure your water inlet isn't plugged, then check that your solenoid is opening fully, unless this is an old model and you have calcium buildup throughout the machines plumbing I'd bet a new solenoid will fix you right up.
Feb 22, 2010 | Dishwashers
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishes not coming out clean
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Nov 12, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishes not clean
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Dishwashers Logo
53 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
