Question about Karcher 2500 PSI Pressure Washer
My Hondo ZR 3700 13 HP GX 390 Pressor washer will not start I have the Choke set and the gas line on.
3 Suggested Answers
SOURCE: Press. Washer Honda engine gx 390 will not start
did you leave fuel in it from last year, if so remove all fuel from tank, drain carb. (remove float bowl if it doesn't have a drain bolt) put in fresh fuel, check your oil level and you should be good to go. if not, please take it to a qualified tech. for carb. cleaning.
Doc
Posted on May 17, 2010
wmpcs
  • 100 Answers
SOURCE: We need a manual for
The numbers you have listed are for the engine, Honda doesn't actually make pressure washers but makes the engines. If you are looking for the manual on the pressure washer itself you are going to have to find some other numbers that should be listed on the frame of the machine.
Posted on Nov 01, 2010
My Honda gx 390engin will start but sputters as if missing while in idle and at higher rpms whats wrong
inside the carburetor you have to clean the main jet and nozzle first shut fuel off,remove the bottom bolt of fuel bowl and pull away,inside the stem where bolt came out of are the jet and nozzle using a #2 screwdriver insert in the stem and carefully remove jet without stripping it the nozzle is behind the jet you would need a small tool like a bolt extractor or easy out to pull the nozzle down it may be stuck from the varnished fuel.i usually use a small dry wall screw and insert it in the hole,twist then pull:),clean all the ports re install and it should run like a champ.if engine still hunts during open choke also try removing the pilot jet by removing the plastic screw then the spacer underneath then pry the jet using the screwdriver this jet is very tiny i would use a bristle out off the wire brush if possible.
Sep 30, 2014 | Honda 13 HP Engine w/electric start - GX...
Trouble shooting New Toro Power Clear 418 zr - slight misses and pops while running
when you start it do u use the choke right , when starting close choke when it starts open choke you prob fouled the plug clean it put back it walah
Nov 22, 2013 | Toro Power Clear 418 ZR - Single Stage...
I have a kawasaki zr 750 h1, i start it up fine but 10 mins down the road she splutters and stalls ( yes she does have petrol!) any ideas on what could be wrong?
Sounds like a malfunction vacuum petcock. Possibly just a cracked or leaking vacuum line operating the vacuum diaphragm. With the choke on there is enough vacuum to operate the petcock , but as it warms up the reduced flow from the partially closed petcock feeder line causes you to run out of gas when trying to drive at speed. Check the vacuum line for damage and replace if necessary. Check the fuel petcock for internal damage. If vacuum diaphragm is cracked or has a pinhole replace the petcock assembly about $75)(K&L may have a rebuild kit about $30).
Jun 30, 2011 | 2002 kawasaki ZR-7
We need a manual for our pressure washer 3700 PSI, 13 HP-GX 390. How do we get this?
Nov 01, 2010 | Honda Garden
Doc
May 17, 2010 | Karcher G3025OH Pressure Washer
I have a Honda GX 390 with 13 hp power washer. Overheating.
Make sure the engine is not full of paint or dust debris in it's cooling system. If the fuel mixture setting is very lean, it can cause overheating. Make sure the fuel tank vent is open to prevent fuel starvation. Does the engine seem to be running at full operational speed? If not, it will be short on developed horsepower. Make sure the water source is not partially shut off. Hope some of this helps!
Feb 25, 2010 | Air Tools & Compressors
Honda gx 390 only starts when it feels like it
Sometimes you have to lower the air pressure in the tank to allow it to run. The back pressure from the compressed air in the compressor head overcomes the pressure created in the engine at the slow RPMs you are able to pull while attempting to crank it.
Aug 13, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Karcher 2500 PSI Pressure Washer Logo
120 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
